Another 914 goes under the knife, UPDATE: IT'S ALIVE....FINALLY |
vintage914racer |
Dec 8 2013, 12:36 AM
Member Group: Members Posts: 429 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
Today was a chilling day, both figuratively and literally. You see, I dropped off my 1970 914-6 for some long overdue structural repairs in Northern Minnesota. It was both freakishly cold and a milestone in my 914 ownership.
A little backstory.... Since I was was a kid cars have been a part of my life, particularly 914s. In the early 1980's my father, who was in his early 30's, was diagnosed with cancer and endured months of experimental treatment at the U of M. Miraculously he overcame the odds and entered remission. Upon paying back his medical bills he celebrated by purchase a 1970 914-6. This particular car brings back many fond memories from my childhood. I remember riding in between my parents in the front seat, urging my dad to go faster. I remember riding in the car as we drove up to Brainerd International Raceway to watch the IMSA Camel GT series run. I remember my school age friends looking at the speedometer in awe, simply blown away that it went up to 180mph. As a kid I affectionately referred to the car as "Speedy." Long story short, the car fell into my possession many years later following my father's passing and would become a reminder of the great times I spent with him. The car spent the majority of the last 20-years languishing in our garage. It was brought back to life mechanically, but had a number of battle wounds that accumulated both by me as a lackadaisical kid and from corrosion on the non-galvanized body. Knowing that a car does not do wel sitting, I enthusiastically drove it whenever I could. In fact the last couple years I had it on the road I probably average 3k miles per year, which is a lot for a sports car in Minnesota where it snows 6 months out of the year...more on this later. Deep down I knew that the car suffered from corrosion and I finally faced it head on when I removed the rocker covers just over a year ago. I soon discovered that the car suffered in the usual rust areas. So much that I was no longer comfortable driving it. The passenger side needed an inner and outer long. The drivers side needed an outer panel. I found that the rear half of the floorpan required replacement. Surprisingly, the hell hole was in pretty decent shape. Despite having some little welding experience under my belt I knew the repairs weren't in my wheelhouse. After consulting the 914world brain trust I quickly learned that that the solution to my problems was just a couple hour drive away. Rick, aka Rick918S, has torn apart a number of 914s and after some back and forth he agreed to tackle the project. Before hauling the car up north, I pulled the engine and interior. Upon pulling the engine I learned that the car no longer has it's original motor, rather is has one from a 68s. For the record the engine is stamped with 901/02 and serial number 4080519. Makes sense since the car seemed to have more zip than 110hp brings. Once stripped of the engine I loaded it up on my trailer in anticipation of the pilgrimage north. So, this morning at the crack of dawn I hopped in my truck and made the 2.5 hour trip to Duluth, MN, with the car. Normally a trip to Duluth isn't a big deal, however the weather made it a bit more exciting. Earlier this week we got dumped on by snow. In the Minneapolis metro we got about 8-inches. Duluth got closer to 18-inches. If the snow along wasn't enough, the temperature brought things to a new level. When I left my house in Minneapolis the temperature read -7 degrees. As I got closer to Duluth the thermometer dropped to -19F. Soon thereafter it dropped to -26. Part of me thought the car would break down and I would become a human popsicle. With inconsistently plowed roads part of me also thought I would careen off the road, but with a stroke of luck I made it to Duluth in one piece. Rick and I unloaded the car quickly in an effort to escape the cold and rolled the car into his shop. At present the car sits in good company next to a 1960s Mercedes roadster. Whereas the 914 normally hibernates during winters, this year it will partake in a makeover program. The aforementioned structural elements will get repaired. Concurrently I will be putting the engine on a stand to adjust the valves and replacing gaskets and seals as needed. I'll open the transmission to make sure everything looks good. I plan to replace the sail panel vinyl, carpet, shocks and rechrome the rear bumper. Inevitably, the slop will get more slippery. The goal is to have a stong structural and mechanical foundation come spring. Once complete, I'll drive the car for a few years before tackling the superficial cosmetic blemishes. Stay tuned for a photo diary of the progress. |
rick 918-S |
Jan 29 2014, 03:14 PM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I started welding in the floor pan on the passenger side. I drilled through the bottom of the long and plug welded the pan from the top side. Then I used my spot welder and spot welded the pan also. It looks stock with spot welds not big mig rosettes.
I left the long clam shell off until I have completed all the pan welds. I was able to use my pinch spotter that way. Made up a new bracket of the heater tube. |
Lo-Fi Version | Time is now: 7th May 2024 - 08:25 PM |
