Another 914 goes under the knife, UPDATE: IT'S ALIVE....FINALLY |
vintage914racer |
Dec 8 2013, 12:36 AM
Member Group: Members Posts: 429 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
Today was a chilling day, both figuratively and literally. You see, I dropped off my 1970 914-6 for some long overdue structural repairs in Northern Minnesota. It was both freakishly cold and a milestone in my 914 ownership.
A little backstory.... Since I was was a kid cars have been a part of my life, particularly 914s. In the early 1980's my father, who was in his early 30's, was diagnosed with cancer and endured months of experimental treatment at the U of M. Miraculously he overcame the odds and entered remission. Upon paying back his medical bills he celebrated by purchase a 1970 914-6. This particular car brings back many fond memories from my childhood. I remember riding in between my parents in the front seat, urging my dad to go faster. I remember riding in the car as we drove up to Brainerd International Raceway to watch the IMSA Camel GT series run. I remember my school age friends looking at the speedometer in awe, simply blown away that it went up to 180mph. As a kid I affectionately referred to the car as "Speedy." Long story short, the car fell into my possession many years later following my father's passing and would become a reminder of the great times I spent with him. The car spent the majority of the last 20-years languishing in our garage. It was brought back to life mechanically, but had a number of battle wounds that accumulated both by me as a lackadaisical kid and from corrosion on the non-galvanized body. Knowing that a car does not do wel sitting, I enthusiastically drove it whenever I could. In fact the last couple years I had it on the road I probably average 3k miles per year, which is a lot for a sports car in Minnesota where it snows 6 months out of the year...more on this later. Deep down I knew that the car suffered from corrosion and I finally faced it head on when I removed the rocker covers just over a year ago. I soon discovered that the car suffered in the usual rust areas. So much that I was no longer comfortable driving it. The passenger side needed an inner and outer long. The drivers side needed an outer panel. I found that the rear half of the floorpan required replacement. Surprisingly, the hell hole was in pretty decent shape. Despite having some little welding experience under my belt I knew the repairs weren't in my wheelhouse. After consulting the 914world brain trust I quickly learned that that the solution to my problems was just a couple hour drive away. Rick, aka Rick918S, has torn apart a number of 914s and after some back and forth he agreed to tackle the project. Before hauling the car up north, I pulled the engine and interior. Upon pulling the engine I learned that the car no longer has it's original motor, rather is has one from a 68s. For the record the engine is stamped with 901/02 and serial number 4080519. Makes sense since the car seemed to have more zip than 110hp brings. Once stripped of the engine I loaded it up on my trailer in anticipation of the pilgrimage north. So, this morning at the crack of dawn I hopped in my truck and made the 2.5 hour trip to Duluth, MN, with the car. Normally a trip to Duluth isn't a big deal, however the weather made it a bit more exciting. Earlier this week we got dumped on by snow. In the Minneapolis metro we got about 8-inches. Duluth got closer to 18-inches. If the snow along wasn't enough, the temperature brought things to a new level. When I left my house in Minneapolis the temperature read -7 degrees. As I got closer to Duluth the thermometer dropped to -19F. Soon thereafter it dropped to -26. Part of me thought the car would break down and I would become a human popsicle. With inconsistently plowed roads part of me also thought I would careen off the road, but with a stroke of luck I made it to Duluth in one piece. Rick and I unloaded the car quickly in an effort to escape the cold and rolled the car into his shop. At present the car sits in good company next to a 1960s Mercedes roadster. Whereas the 914 normally hibernates during winters, this year it will partake in a makeover program. The aforementioned structural elements will get repaired. Concurrently I will be putting the engine on a stand to adjust the valves and replacing gaskets and seals as needed. I'll open the transmission to make sure everything looks good. I plan to replace the sail panel vinyl, carpet, shocks and rechrome the rear bumper. Inevitably, the slop will get more slippery. The goal is to have a stong structural and mechanical foundation come spring. Once complete, I'll drive the car for a few years before tackling the superficial cosmetic blemishes. Stay tuned for a photo diary of the progress. |
rick 918-S |
Feb 6 2014, 12:17 AM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I spot welded the outer long today. I used a pinch spotter to close it up like the factory.
I misted on some self etching primer and added a bead of urethane seam sealer to the top edge as the factory did. Then I added the sill panel. I used my Lenco panel spotter to face spot the panel and used the pinch spotter to spot weld the braces to the sill. Here is the bottom of the sill after installing. The seam sealer is squeezed out and prevents moisture from starting rust under it. |
Lo-Fi Version | Time is now: 7th May 2024 - 08:06 AM |
