Brake Pad Recommendation, Street/HPDE |
andys |
Dec 11 2013, 04:32 PM
I'm still wanting to get my car to the track to do some suspension adjustments, and get a feel for how the car responds at its limit. I like to use HPDE's as test sessions to set up the car. Just a reminder, my car is an LS1 conversion with '89 Carerra suspension/brakes. That said, I'd like some opinions/recommendations on what pads to run. What I'd prefer, is a pad that's good enough for a bit of track time without too much fading, and serve well on the street without the annoyance of squeal. I'm not opposed to having a street pad and a track pad, but then bedding becomes a problem. Opinions?
Thanks, Andys |
brant |
Dec 11 2013, 04:35 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
r4s
ChrisFoley |
Dec 11 2013, 04:47 PM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I'm still wanting to get my car to the track to do some suspension adjustments, and get a feel for how the car responds at its limit. I like to use HPDE's as test sessions to set up the car. Just a reminder, my car is an LS1 conversion with '89 Carerra suspension/brakes. That said, I'd like some opinions/recommendations on what pads to run. What I'd prefer, is a pad that's good enough for a bit of track time without too much fading, and serve well on the street without the annoyance of squeal. I'm not opposed to having a street pad and a track pad, but then bedding becomes a problem. Opinions? Thanks, Andys None of the high performance street pads like high sustained temps. But the medium temp (800F) track pads will squeal when you approach a stop light on the road. I would stay away from swapping pads back and forth unless you're prepared to clean the rotors every time you switch. I guess your usage description points more to a good street pad, as long as you're mindful of their temp limitations on the track and don't run balls out for 30 minutes. I'd try the KFP 1935 compound we sell for street/AX cars. I know they're quiet and they have a pretty good C/F. |
podiummotorsports |
Dec 11 2013, 05:04 PM
Newbie Group: Members Posts: 39 Joined: 7-October 12 From: Rossmoor, CA Member No.: 15,011 Region Association: Southern California |
Having raced for many years and have tried just about everything. I am convinced that Carbotech is the best solution. You would need to call them to get their opinion on what they would suggest for your application but as far as feel, performance and stopping, I don't think you will find a better pad.
http://www.ctbrakes.com/ They will also pre bed them for you. |
Eric_Shea |
Dec 11 2013, 05:10 PM
r4s (IMG:style_emoticons/default/agree.gif) but, I'd want to know more about a "good amount of track time" The Porterfield R41 is a vintage race compound that may do the trick. |
andys |
Dec 11 2013, 05:30 PM
Ok, so I need to elaborate a bit. I'll be running at The Streets of Willow which, depending on the direction they run, only has one serious braking zone where you have to set it down form speed. Otherwise, it's a fairly low speed technical course, though you do use the brakes often. Granted, the LS1 will get the car rolling to speed pretty quick. The HPDE sessions are 20 minutes, so that makes it a bit more brake freindly. Yeah, I've heard R4S are good, but have no experience with them.
Andys |
Dec 11 2013, 05:44 PM
I'll be running at The Streets of Willow which, depending on the direction they run, only has one serious braking zone where you have to set it down form speed. If you're running clockwise, there's actually two places where you can get some good speed. One is obviously at the end of the main straight but there's also the back straight after the bowl (turn 8? if i recall correctly). In my car, i can take 9 pretty much flat out and then have to brake very hard for 10/11 while trying to keep the car straight. (IMG:style_emoticons/default/driving.gif) |
andys |
Dec 11 2013, 06:11 PM
I'll be running at The Streets of Willow which, depending on the direction they run, only has one serious braking zone where you have to set it down form speed. If you're running clockwise, there's actually two places where you can get some good speed. One is obviously at the end of the main straight but there's also the back straight after the bowl (turn 8? if i recall correctly). In my car, i can take 9 pretty much flat out and then have to brake very hard for 10/11 while trying to keep the car straight. (IMG:style_emoticons/default/driving.gif) If they run SOW counter clockwise, then you pick up the most speed going down hill on the front straight, then hard braking before the skid-pad turn. CCW is my least favorite direction. Clockwise, you have to really attach the track and get a good rythm going. Been running there since it opened, but never in a 914, so that'll be a new experience. Andys |
Lo-Fi Version | Time is now: 22nd May 2024 - 08:00 AM |
