911 back on the road, whack, whack, whack, whack |
Dec 14 2013, 05:29 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You've got to be kidding me ? (IMG:style_emoticons/default/dry.gif) Take the damn wheel off, pop off the grease cap, grab an allen key, turn the nut down and tighten up the allen bolt. THIS IS ONLY TO GET IT BACK TO THE SHOP, to have your " mechanic " take another failed look at it. Fer Christs sake boy you work for one of the most notorious Porsche specialty shop's in the southeast (IMG:style_emoticons/default/mellow.gif) (IMG:style_emoticons/default/agree.gif) |
ripper911 |
Dec 14 2013, 06:29 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
You've got to be kidding me ? (IMG:style_emoticons/default/dry.gif) Take the damn wheel off, pop off the grease cap, grab an allen key, turn the nut down and tighten up the allen bolt. THIS IS ONLY TO GET IT BACK TO THE SHOP, to have your " mechanic " take another failed look at it. Fer Christs sake boy you work for one of the most notorious Porsche specialty shop's in the southeast (IMG:style_emoticons/default/mellow.gif) (IMG:style_emoticons/default/agree.gif) Will do, thanks for the tip. Hopefully that will get me back to the shop at least. |
CG-914 |
Dec 16 2013, 12:36 AM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Jack tube is the best way! Unless rusted of course!
If rusted: do it as Spoke said! If you cant use the Jack tube, use a block of rubber or wood when you jack it up! And to tighten those wheel bearings is not hard at all! |
ripper911 |
Dec 19 2013, 11:23 AM
I haven't done any work on this yet as I've been quite sick, but someone told me something that I want to write down here so that I don't forget.
When you tighten the 6mm allen nut or whatever it is, only tighten it to the point that it just stops, don't torque it past that point. Correct me if I'm wrong. |
SLITS |
Dec 19 2013, 11:40 AM
If you're talking about the nut that holds the hub onto the spindle, it is a pinch nut. I would give it a bit more than just "when it stops". If the nut is not secured on the spindle, it can back off and you're gonna lose a wheel in the worst case.
Don't use a 4' breaker bar on it, but do tighten the pinch screw securely. |
Dec 19 2013, 11:56 AM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
You tighten the nut until you can just barely move the washer behind it by pushing it (not prying on it!) with a screwdriver. Then you tighten the little Allen screw that keeps the nut from rotating.
I believe that one of the sides is reverse threaded. --DD |
Dec 19 2013, 12:06 PM
You tighten the nut until you can just barely move the washer behind it by pushing it (not prying on it!) with a screwdriver. Then you tighten the little Allen screw that keeps the nut from rotating. I believe that one of the sides is reverse threaded. --DD Then you drive it around the block and pull it back in and do it again. So you need to do it twice. rich |
Lo-Fi Version | Time is now: 4th June 2024 - 04:37 AM |
