leaky hoosier safe?, ehhh? |
May 26 2003, 11:51 PM
Group: Posts: 0 Joined: -- Member No.: 0 |
I have 1 leaky hoosier, is it still safe to run on? If I put in 35lbs today, tomorow, it will be about 30. about 5-7lbs a day.
I'm scared! (IMG:style_emoticons/default/confused24.gif) |
GWN7 |
May 27 2003, 01:31 AM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Leaky valve stem? or bead seal? Check for leak with dish soap & water. Silicone on the inside of the bead seal. R&R valve stem. You could try one of those fix-a-flat in a cans, if it's weeping thru the tire. Should stop it leaking.
Lo-Fi Version | Time is now: 16th May 2024 - 08:46 PM |
