Removing the rocker panel |
rmital |
Dec 21 2013, 03:23 PM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
r_towle |
Dec 21 2013, 04:18 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Depending upon what you are doing, you can remove the bottom fasteners and pull it out without touching the top.
You can use air or water at that point to get all the stuff out. Again, if you buy 1/2 inch thick rubber spacers from the plumbing section of the hardware store, and longer stainless screws, you can space out the bottom and you won't see it, but all the crud can now fall out, all the time.....and never build up. |
boxsterfan |
Dec 21 2013, 06:57 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Depending upon what you are doing, you can remove the bottom fasteners and pull it out without touching the top. You can use air or water at that point to get all the stuff out. Again, if you buy 1/2 inch thick rubber spacers from the plumbing section of the hardware store, and longer stainless screws, you can space out the bottom and you won't see it, but all the crud can now fall out, all the time.....and never build up. Anybody got a pic of that? I am looking to take my rockers off soon for the first time. Wish me luck!! |
Lo-Fi Version | Time is now: 15th May 2024 - 08:50 PM |
