> Apparently I need a new computer for my 1974 2.0 with D-jet fuel injection, Fuel Injection running too rich. Anybody know where to find NOS, rebuilt units or know where to send to repair one?
tumamilhem
post Dec 22 2013, 12:05 PM
Post #21
LUFTBRIGADE
Apparently the computer in my 1974 2.0 is not working properly and making the car run rich. Does anybody know where I can find another one or who to go to have mine rebuilt? It's for a 1974 2.0 with D-jet fuel injection.
Also my 3rd cylinder is misfiring. Would this have anything to do with the computer? If not, any idea what may be causing it to misfire? I have a new working AAR valve installed, my MPS works, no bad wiring in the wire harness or spark plug wires, the timing and dwell are on point and the valves are adjusted.
tumamilhem   Apparently I need a new computer for my 1974 2.0 with D-jet fuel injection   Dec 22 2013, 12:05 PM
brant   there should be someone with one in the classified...   Dec 22 2013, 12:11 PM
JawjaPorsche   Pelican Parts http://www.pelicanparts.com/cgi-bin...   Dec 22 2013, 12:26 PM
tumamilhem   Yes, CHTS ohm reading checks out fine and the inje...   Dec 22 2013, 12:34 PM
brant   I believe the computer is only for adjusting and m...   Dec 22 2013, 12:49 PM
tumamilhem   Thanks for the tip, Brant. He checked the plugs. T...   Dec 22 2013, 01:03 PM
914itis   What's the part number on the computer? I may ...   Dec 22 2013, 01:10 PM
rhodyguy   post the ecu #. :agree:   Dec 22 2013, 01:18 PM
Jeff Bowlsby   Could be a bad injector on #3...was that checked f...   Dec 22 2013, 01:24 PM
euro911   Check/clean the trigger points?   Dec 22 2013, 03:11 PM
SirAndy   Apparently the computer in my 1974 2.0 is not work...   Dec 22 2013, 03:37 PM
r_towle   Apparently the computer in my 1974 2.0 is not wor...   Dec 22 2013, 03:45 PM
euro911   Jeff, don't you have an ECU test board/box?   Dec 22 2013, 03:42 PM
Jeff Bowlsby   Jeff, don't you have an ECU test board/box? ...   Dec 22 2013, 05:15 PM
r_towle   Just saw you are in Jacksonville Florida. How clos...   Dec 22 2013, 03:47 PM
stugray   I have a complete 2.0L FI system with ECU, 5 Green...   Dec 22 2013, 03:53 PM
rhodyguy   i would talk to one of the 2 joes at SERIES9. buy ...   Dec 22 2013, 04:51 PM
Cap'n Krusty   Make sure ALL the ground wires under the intake pl...   Dec 22 2013, 04:59 PM
Ferg   I have one for I think a 73 2.0 part # 0 280 000 ...   Dec 22 2013, 05:42 PM
r_towle   I have two bosch Djet test machines if you think t...   Dec 22 2013, 05:53 PM
tumamilhem   I have two bosch Djet test machines if you think ...   Dec 23 2013, 04:02 PM
SirAndy   Thank you guys for all the input suggestions. I wi...   Dec 23 2013, 04:18 PM
tumamilhem   Thank you guys for all the input suggestions. I w...   Dec 24 2013, 09:01 AM
tumamilhem   I have two bosch Djet test machines if you think ...   Dec 30 2013, 05:30 AM
tumamilhem   Hey guys! Haven't been able to check back ...   Dec 23 2013, 06:08 AM
Java2570   I'd take Andy's advice above, have your FI...   Dec 23 2013, 04:27 PM
JRust   Knowing the issues I had getting the FI to run rig...   Dec 24 2013, 12:41 AM
tumamilhem   Knowing the issues I had getting the FI to run ri...   Dec 24 2013, 09:04 AM
JRust   Knowing the issues I had getting the FI to run r...   Dec 24 2013, 03:49 PM
tumamilhem   [quote name='tumamilhem' post='1974386' date='Dec...   Dec 30 2013, 05:27 AM
wilchek   Very similar to an issue I was having with my car ...   Dec 24 2013, 06:39 AM
tumamilhem   Very similar to an issue I was having with my car...   Jan 1 2014, 10:29 AM
KELTY360   Very similar to an issue I was having with my ca...   Jan 1 2014, 11:41 AM
tumamilhem   FYI Since he has my car, I forwarded this thread t...   Dec 24 2013, 09:13 AM
rhodyguy   send your fi harness to jeff bowlsby. if it's ...   Jan 1 2014, 11:16 AM
tumamilhem   I considered that at first so I specifically inqui...   Jan 1 2014, 11:38 AM
- Lo-Fi Version Time is now: 9th July 2025 - 05:06 PM
