Build #2, No huge car progress...but...cool new toys! |
jd74914 |
Dec 24 2013, 11:09 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Hello all.
I figured I’d throw up a progress thread for my car’s second rebuild. For those who don’t know me my name is James and I’ve been a 914 addict since age 13 (now 26) and used to hang around here a bunch more. It seems like a good start to this thread would be some background information. Its first build took place when I was in high school (age 13) and ended as a freshman in college. When I originally purchased the car it didn’t run and had some pretty serious external rust problems. I rebuilt the motor, fixed tons of electrical issues, replaced all of the rotten metal with new (all hand-formed since I didn’t have the money to pay for reproduction pieces), and repainted. Everything was done in my garage with the exception of turning/balancing the flywheel and I learned how to MIG weld and paint from my dad, some books, and through a lot of practice. After reassembly, it was my daily driver for 3.5 years during my undergrad degree. I pretty much drove it hard and put it away wet for the entirety of these years and it never saw a garage. Something about getting a mechanical engineering degree, dating a few girls, working throughout the year as a design engineering intern, and finding FSAE cars really limited the amount of time I spend on my own car. By the end of my undergrad degree there were some pretty rough spots, mostly in terms of the suspension/brakes and a pesky ignition switch (replaced 3 or 4 times and it kept failing), which pushed me to taking it off the road and fixing everything correctly. I thought it might take about a year-that was 3.5 years ago! (IMG:style_emoticons/default/wacko.gif) Just like after the first rebuild, life got in the way and the car sat as I went through a master’s degree, worked full time, continued to play with FSAE cars, and starting working on friend’s real racecars. Now I’ve finally finished my MS (and know way too much about fluid dynamics and heat transfer (IMG:style_emoticons/default/laugh.gif) ), am applying to schools for a Ph.D., still haven’t stopped [advising] FSAE design, and really want to drive her! The play was to start and finish rebuilding the suspension last summer (I saw Chris Foley-Racer Chris in the grocery store one day and told him this), but I got carried away and a bit behind. This thread is to chronicle the build back to the road. We’ll start with a few pictures from when it was originally completed in 2006/7 (well, it's missing the plates and still has the original windshield but...). |
jd74914 |
Dec 24 2013, 11:41 PM
***** Hijack Start *****
Since it’s been my main non-academic/vocational distraction for the last 7 years, a few OT FSAE pictures are probably warranted. For those who don’t know, FSAE is a college competition in which teams design and build a formula-style racecar for international competition. The cars are new every year, and the teams cycle members about every 3-4 years since they are academically-linked. I personally think it is the best learning experience for future engineers. And now for the sale’s plug: If anyone is interested in donating funds, components, or machining/RPing time, the guys would love to talk to you. 2013 UCONN FSAE Quick Spec. Notes Suspension 10" wheels, 18.5x7.5" tires Cast magnesium uprights 75 and 85 mm deep groove ball bearings Custom "hindle" - Integrated hub, spindle, wheel center(6061-T6) with 4340 RC50 tripod inserts Symmetric hindle design (same for all 4 corners) LSA suspension, push-rod actuated dampers, front ARB 100% Ackermann 30 deg max steering angle Kaz Tech/Cane Creek double-adjustable dampers Brakes Wilwood PS-1 Titon rear-pivot masters Remote-mount bias adjust Drivetrain Semi-custom salisbury differential (built using BMW E30 LSD clutches and ramps) Cast magnesium case, aluminum end caps 15.9# overall weight (including mounting pillow blocks, bearings, sprocket, stub axles, etc.) Custom 4340 tripod stub axles 3 speed transmission, max speed 77.9 mph @ 12 krpm (which has problems eating gears...now drive 2nd and driven 2nd and 6th are cryo'd and shot-peened) Chassis 4130, TIG welded, normalized 1800 ft-lb/degree twist 65# base frame weight, 70# fully loaded (not incl. stressed panels) CFRP stressed floor, firewall, rear bulkhead 435# assembled weight goal (haven't weighed yet) Engine/Controls 2001-2003 GSX-R600 motor 13:1 compression Est. 85 hp @ 9.5 krpm, 45 ft-lb @ 8 krpm Eq. length 4-2-1 headers tuned for 2nd resonant freq. @ 7.5 krpm, 18 ga mild steel, ceramic coated Ti Akropovic muffler Intake tuned for 2nd resonant freq. @ 8.5 krpm, 40% glass-filled nylon SLS 28mm SLS throttle body Performance Electronics PE-3 ECU Texense shift cut (programmed ignition cut in ECU for clutchless shifting) Manual shifter/hand clutch |
Lo-Fi Version | Time is now: 18th May 2024 - 05:08 PM |
