Build #2, No huge car progress...but...cool new toys! |
jd74914 |
Dec 24 2013, 11:09 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Hello all.
I figured I’d throw up a progress thread for my car’s second rebuild. For those who don’t know me my name is James and I’ve been a 914 addict since age 13 (now 26) and used to hang around here a bunch more. It seems like a good start to this thread would be some background information. Its first build took place when I was in high school (age 13) and ended as a freshman in college. When I originally purchased the car it didn’t run and had some pretty serious external rust problems. I rebuilt the motor, fixed tons of electrical issues, replaced all of the rotten metal with new (all hand-formed since I didn’t have the money to pay for reproduction pieces), and repainted. Everything was done in my garage with the exception of turning/balancing the flywheel and I learned how to MIG weld and paint from my dad, some books, and through a lot of practice. After reassembly, it was my daily driver for 3.5 years during my undergrad degree. I pretty much drove it hard and put it away wet for the entirety of these years and it never saw a garage. Something about getting a mechanical engineering degree, dating a few girls, working throughout the year as a design engineering intern, and finding FSAE cars really limited the amount of time I spend on my own car. By the end of my undergrad degree there were some pretty rough spots, mostly in terms of the suspension/brakes and a pesky ignition switch (replaced 3 or 4 times and it kept failing), which pushed me to taking it off the road and fixing everything correctly. I thought it might take about a year-that was 3.5 years ago! (IMG:style_emoticons/default/wacko.gif) Just like after the first rebuild, life got in the way and the car sat as I went through a master’s degree, worked full time, continued to play with FSAE cars, and starting working on friend’s real racecars. Now I’ve finally finished my MS (and know way too much about fluid dynamics and heat transfer (IMG:style_emoticons/default/laugh.gif) ), am applying to schools for a Ph.D., still haven’t stopped [advising] FSAE design, and really want to drive her! The play was to start and finish rebuilding the suspension last summer (I saw Chris Foley-Racer Chris in the grocery store one day and told him this), but I got carried away and a bit behind. This thread is to chronicle the build back to the road. We’ll start with a few pictures from when it was originally completed in 2006/7 (well, it's missing the plates and still has the original windshield but...). |
jd74914 |
Jan 1 2015, 01:09 PM
Awesome job rebuilding the long! Thanks! If you want to play with and experiment with a needle bearing for cheap, pay shipping and I'll send you an old unused Nadella bearing that was left over from when I used to make the kits. That would be awesome! PM sent! (IMG:style_emoticons/default/smile.gif) Andy and I talked about this a bit. The problem is the misalignment washers are really quite thick. Would need to rengineer the kit to accommodate them. Looking at it there really isn't much room in there unless you grind off part of the control arm not a bid deal, or recess the shafts into the arm. I went this way mostly for cost since everything is new anyways. Even good spherical bearings are pretty cheap compared to the Nadella rollers. The inner ear will bend/deflect a little bit when adjusting toe. Trust me. I like those pivot shafts! Interesting...I wish I had looked more closely when pulling everything off. Thanks Jeff! I'm hoping I can pull this off with a level of quality near your car's! This setup should eliminate the bind when adjusting rear toe... Yep, mine is quite similar to that on the frame side. used bearing cups from UB Machine because I didn't really feel like machining customs ones. The main difference between that setup and mine is that I didn't weld threaded bushings straight into the trailing arm and instead pressed in an assembly to ensure co-linearity. |
Lo-Fi Version | Time is now: 25th May 2024 - 01:25 PM |
