Build #2, No huge car progress...but...cool new toys! |
jd74914 |
Dec 24 2013, 11:09 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Hello all.
I figured I’d throw up a progress thread for my car’s second rebuild. For those who don’t know me my name is James and I’ve been a 914 addict since age 13 (now 26) and used to hang around here a bunch more. It seems like a good start to this thread would be some background information. Its first build took place when I was in high school (age 13) and ended as a freshman in college. When I originally purchased the car it didn’t run and had some pretty serious external rust problems. I rebuilt the motor, fixed tons of electrical issues, replaced all of the rotten metal with new (all hand-formed since I didn’t have the money to pay for reproduction pieces), and repainted. Everything was done in my garage with the exception of turning/balancing the flywheel and I learned how to MIG weld and paint from my dad, some books, and through a lot of practice. After reassembly, it was my daily driver for 3.5 years during my undergrad degree. I pretty much drove it hard and put it away wet for the entirety of these years and it never saw a garage. Something about getting a mechanical engineering degree, dating a few girls, working throughout the year as a design engineering intern, and finding FSAE cars really limited the amount of time I spend on my own car. By the end of my undergrad degree there were some pretty rough spots, mostly in terms of the suspension/brakes and a pesky ignition switch (replaced 3 or 4 times and it kept failing), which pushed me to taking it off the road and fixing everything correctly. I thought it might take about a year-that was 3.5 years ago! (IMG:style_emoticons/default/wacko.gif) Just like after the first rebuild, life got in the way and the car sat as I went through a master’s degree, worked full time, continued to play with FSAE cars, and starting working on friend’s real racecars. Now I’ve finally finished my MS (and know way too much about fluid dynamics and heat transfer (IMG:style_emoticons/default/laugh.gif) ), am applying to schools for a Ph.D., still haven’t stopped [advising] FSAE design, and really want to drive her! The play was to start and finish rebuilding the suspension last summer (I saw Chris Foley-Racer Chris in the grocery store one day and told him this), but I got carried away and a bit behind. This thread is to chronicle the build back to the road. We’ll start with a few pictures from when it was originally completed in 2006/7 (well, it's missing the plates and still has the original windshield but...). |
914forme |
Dec 30 2016, 07:44 AM
Jim
3/8" due to me having a huge number of 3/8" hardware on hand. The speedway stuff is super nice, you can make it double sheer by cutting it down to the area needed for bar engagement and then welding on so sides. Since it is AL, you will need thicker pieces than mine. Which where over kill at 3/16" I could have done it with 1/8" but the bar I am using is huge compared to the one I modeled it after. I understand the holistic education keep it up. As for the need for machine tools in the garage, I waited 30 years before I got a Metal Lathe and Mill. They are small units, yet now I think why did I never have the Lathe before. IT is the most used item in the shop even surpassed the welders. (IMG:style_emoticons/default/confused24.gif) Mill gets used about 1/16th as much. I now need a bigger Lathe, and well I would love to have an larger mill but they take up a lot of space, for the little usage it would get. |
jd74914 |
Jan 4 2017, 04:38 PM
3/8" due to me having a huge number of 3/8" hardware on hand. The speedway stuff is super nice, you can make it double sheer by cutting it down to the area needed for bar engagement and then welding on so sides. Since it is AL, you will need thicker pieces than mine. Which where over kill at 3/16" I could have done it with 1/8" but the bar I am using is huge compared to the one I modeled it after. Ok, gotcha. From a load standpoint 5/16" seems ok so I'm thinking about going that way since I have a ton of 5/16" stuff from another project. Yeah, I'm not sure about welding yet. I'm comfortable welding steel ends, but the post-weld non-heat treated aluminum scares me a little bit. Got another idea but need to do some more thinking. I waited 30 years before I got a Metal Lathe and Mill. They are small units, yet now I think why did I never have the Lathe before. IT is the most used item in the shop even surpassed the welders. (IMG:style_emoticons/default/confused24.gif) Mill gets used about 1/16th as much. Interesting. In car fab like this I guess you do tend to need lots of pieces turned and there isn't really any other machine that can do it. Lathe first then! (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 24th May 2024 - 11:01 PM |
