Build #2, No huge car progress...but...cool new toys! |
jd74914 |
Dec 24 2013, 11:09 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Hello all.
I figured I’d throw up a progress thread for my car’s second rebuild. For those who don’t know me my name is James and I’ve been a 914 addict since age 13 (now 26) and used to hang around here a bunch more. It seems like a good start to this thread would be some background information. Its first build took place when I was in high school (age 13) and ended as a freshman in college. When I originally purchased the car it didn’t run and had some pretty serious external rust problems. I rebuilt the motor, fixed tons of electrical issues, replaced all of the rotten metal with new (all hand-formed since I didn’t have the money to pay for reproduction pieces), and repainted. Everything was done in my garage with the exception of turning/balancing the flywheel and I learned how to MIG weld and paint from my dad, some books, and through a lot of practice. After reassembly, it was my daily driver for 3.5 years during my undergrad degree. I pretty much drove it hard and put it away wet for the entirety of these years and it never saw a garage. Something about getting a mechanical engineering degree, dating a few girls, working throughout the year as a design engineering intern, and finding FSAE cars really limited the amount of time I spend on my own car. By the end of my undergrad degree there were some pretty rough spots, mostly in terms of the suspension/brakes and a pesky ignition switch (replaced 3 or 4 times and it kept failing), which pushed me to taking it off the road and fixing everything correctly. I thought it might take about a year-that was 3.5 years ago! (IMG:style_emoticons/default/wacko.gif) Just like after the first rebuild, life got in the way and the car sat as I went through a master’s degree, worked full time, continued to play with FSAE cars, and starting working on friend’s real racecars. Now I’ve finally finished my MS (and know way too much about fluid dynamics and heat transfer (IMG:style_emoticons/default/laugh.gif) ), am applying to schools for a Ph.D., still haven’t stopped [advising] FSAE design, and really want to drive her! The play was to start and finish rebuilding the suspension last summer (I saw Chris Foley-Racer Chris in the grocery store one day and told him this), but I got carried away and a bit behind. This thread is to chronicle the build back to the road. We’ll start with a few pictures from when it was originally completed in 2006/7 (well, it's missing the plates and still has the original windshield but...). |
jd74914 |
Mar 10 2017, 09:53 AM
Cut up the differential last night and test fit in the transmission. I'm making the 2WD lockout in the same way that 914pipe and jpnovak did by welding the input/output splines on the center differential together.
jpnovak: http://www.914world.com/bbs2/index.php?showtopic=104513 914pipe: http://www.914world.com/bbs2/index.php?sho...p;#entry2419604 My splined pieces look are identical to those of 914pipe; jpnovak had a second, smaller splined section in the middle of his spider section. The guy who owned this thing before me removed the big carrier bearing before selling it to me. I didn't notice at that time (or even really until I tried to slide the thing into my transmission), but he used a BFH to remove the bearing rather than a press and damaged the front edges of a bunch of splines on one side. It took about 30 minutes with some thread files to fix the leading edges and get it slid into the diff. First step is to cut the splines off of the outer casing and spider gear. I cut a bit long on the spider since I wanted to protect the nut/transmission from spatter while tack welding. |
Lo-Fi Version | Time is now: 5th May 2024 - 07:18 AM |
