Build #2, No huge car progress...but...cool new toys! |
jd74914 |
Dec 24 2013, 11:09 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Hello all.
I figured I’d throw up a progress thread for my car’s second rebuild. For those who don’t know me my name is James and I’ve been a 914 addict since age 13 (now 26) and used to hang around here a bunch more. It seems like a good start to this thread would be some background information. Its first build took place when I was in high school (age 13) and ended as a freshman in college. When I originally purchased the car it didn’t run and had some pretty serious external rust problems. I rebuilt the motor, fixed tons of electrical issues, replaced all of the rotten metal with new (all hand-formed since I didn’t have the money to pay for reproduction pieces), and repainted. Everything was done in my garage with the exception of turning/balancing the flywheel and I learned how to MIG weld and paint from my dad, some books, and through a lot of practice. After reassembly, it was my daily driver for 3.5 years during my undergrad degree. I pretty much drove it hard and put it away wet for the entirety of these years and it never saw a garage. Something about getting a mechanical engineering degree, dating a few girls, working throughout the year as a design engineering intern, and finding FSAE cars really limited the amount of time I spend on my own car. By the end of my undergrad degree there were some pretty rough spots, mostly in terms of the suspension/brakes and a pesky ignition switch (replaced 3 or 4 times and it kept failing), which pushed me to taking it off the road and fixing everything correctly. I thought it might take about a year-that was 3.5 years ago! (IMG:style_emoticons/default/wacko.gif) Just like after the first rebuild, life got in the way and the car sat as I went through a master’s degree, worked full time, continued to play with FSAE cars, and starting working on friend’s real racecars. Now I’ve finally finished my MS (and know way too much about fluid dynamics and heat transfer (IMG:style_emoticons/default/laugh.gif) ), am applying to schools for a Ph.D., still haven’t stopped [advising] FSAE design, and really want to drive her! The play was to start and finish rebuilding the suspension last summer (I saw Chris Foley-Racer Chris in the grocery store one day and told him this), but I got carried away and a bit behind. This thread is to chronicle the build back to the road. We’ll start with a few pictures from when it was originally completed in 2006/7 (well, it's missing the plates and still has the original windshield but...). |
jd74914 |
Nov 11 2017, 02:45 PM
No real car progress to report. My crazy school schedule hasn't really been conducive to getting anything done outside of the lab. I've basically only finished the welding on the adapter in the last post.
Once my degree is finished I'll have much more restricted access to machinery, so I've been watching CL and other places for equipment for the garage. Some of you may have seen my mini horizontal mill thread in the Sandbox. My newest score is the Clausing 5907 lathe. It's a 12" swing with hydraulic Reeve drive for continuously variable speed control from 52-2000 rpm (including back gear). It weighs ~1200# so it was a little tough getting off the truck. (IMG:style_emoticons/default/laugh.gif) Everything seems to work quite well and there is very little wear in the ways thanks to the hardening. The cross-slide doesn't have too much back lash and the Reeves drive works well. We'll see if the drive keeps working nicely, if not it'll get removed and replaced with fixed drive. The only real issue at this point is excessive lash in the carriage feed which I believe is caused by a worn bushing singe the rack gear and pinion look good. Looks pretty easy to fix after removing the apron and some people have added a second bearing in the rear part of the casting to kill this problem dead. The owner needed space ASAP in his shop so I got lucky and basically stole it-asking price was less than the value of the new boring bar and insert tool holder. It came with a bunch of new [knockoff] Aloris tool holders, insert tools with spare inserts, and the original lamp post and tool holders. Next parts to find are a nice drill chuck and the MT4-1/2 to 5C adapter to run some collets for smaller jobs. And maybe an independent adjust 4 jaw chuck too. Tough part is finding economical L-00 parts so if anyone has anything... (IMG:style_emoticons/default/rolleyes.gif) It's a 3-phase motor so the next step after doing some cleaning is either finding a 1PH-input/3-PH output VFD or building a converter. Small project and well worth it for the price. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 07:00 AM |
