Picture...Cam Bearing Delamination, Reason for failure?? |
Mueller |
May 27 2003, 10:38 AM
I decided to pop open the case on my 2.0 /4 to replace the cam with a more aggressive one and also to open up some of the passanges for the HD oil pump.
I found the cam bearings to be not in the best shape. Supposedly the motor only had 10k miles on it before I took possesion of it. I do know the motor sat for at least a year before I got it. Attached image(s) |
seanery |
May 27 2003, 10:41 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,841 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
YIKES! (IMG:style_emoticons/default/ohmy.gif)
Lawrence |
May 27 2003, 10:43 AM
Brad Roberts |
May 27 2003, 11:10 AM
They are COOKED !!
What do the rod bearings and mains looke like. I have NEVER seen the material GONE from a cam bearing. B |
J P Stein |
May 27 2003, 11:15 AM
The odd shape of those pits suggests electrolysis.
Iron/water/non-ferros metals.....munchies. Could use a bit more light on the subject, tho. |
Brad Roberts |
May 27 2003, 11:17 AM
When he first said something the other night.. I wondered if water had sat in the bottom of the engine.
B |
Mueller |
May 27 2003, 11:48 AM
The crank bearings look decent, I can tell a few bits of the babbit or bearing media found it's way into the crank bearings.
The cam looks perfect, no signs of wear or discoloration. Dissimilar metals might have done it as JP mentioned. |
Mark Henry |
May 27 2003, 12:33 PM
QUOTE(Brad Roberts @ May 27 2003, 09:17 AM) When he first said something the other night.. I wondered if water had sat in the bottom of the engine. B That would be my first guess! |
Lo-Fi Version | Time is now: 19th April 2024 - 06:23 PM |
