Type IV upgrades and FI, Where's the cut-off to carbs? |
boxsterfan |
Jan 7 2014, 12:42 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
At some point, my motor (1974 2.0L) will need a rebuild. I'm not going to go the /6 conversion on this car. If I rebuild the motor to a 2056 or 2270 displacement, can I still use the FI system (D-jet)? Or is there some spot in here where it is better to switch to carbs? Or if I wanted to have FI then switching to L-Jet instead?
Happy to do some reading if you have it... (IMG:style_emoticons/default/chowtime.gif) |
polo classic |
Jan 9 2014, 02:54 PM
Newbie Group: Members Posts: 32 Joined: 7-October 11 From: Oslo Member No.: 13,650 Region Association: Scandinavia |
Anyone know if the chip in the stock 914 ecu is soldered in?
Anyone had a look at the content on the chip? Shouldn't be that hard to change the fuel table...I have mapped VW Digifant earlier, and the 914 ecu cant be any harder? |
ClayPerrine |
Jan 9 2014, 05:09 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Anyone know if the chip in the stock 914 ecu is soldered in? Anyone had a look at the content on the chip? Shouldn't be that hard to change the fuel table...I have mapped VW Digifant earlier, and the 914 ecu cant be any harder? The 914 fuel injection box is not really a computer. The D-Jet is a bunch of 1960s era big assed transistors. The L-Jet is a little more refined, but there is no real "processor" and there is no such thing as a programmed fuel map. It has a bunch of transistors, resistors, and capacitors that control the fuel map. Changing the fuel map involves replacing resistors to change the mixture curve. Welcome to the 1970s. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 11:56 PM |
