Seing double?, Now tested double D-jet performance! |
larss |
Jan 10 2014, 01:35 AM
Member Group: Members Posts: 428 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
Anybody tried double D-jet air boxes and TB before?
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1389339349.1.jpg) /Lars S |
ChrisFoley |
Jan 10 2014, 07:42 AM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Mine's a little different than what your picture shows.
I made my own plenums. 1911cc with two 1.7L TBs. |
brant |
Jan 10 2014, 07:55 AM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
We have a racer out here running 4 diet throttle bodies
larss |
Jan 10 2014, 08:34 AM
ChrisFoley |
Jan 10 2014, 11:17 AM
any D-jet tuning tips to make double TB's work? Wideband AFM and set up the MPS so you can make adjustments using the info on Brad Anders' site. You'll need to modify the bypass screws to close further since there are now two. Otherwise you won't get the idle down low enough. |
larss |
Jan 10 2014, 12:04 PM
Thanks!
I thought of making the linkage so that one TB is fully closed until 2/3 throttle like a 2 step carb. After 2/3 throttle resistance will be added to the CHT for enrichment. Up till 2/3 hopefully good MPG (IMG:style_emoticons/default/smile.gif) . /Lars S |
ChrisFoley |
Jan 10 2014, 12:11 PM
Thanks! I thought of making the linkage so that one TB is fully closed until 2/3 throttle like a 2 step carb. After 2/3 throttle resistance will be added to the CHT for enrichment. Up till 2/3 hopefully good MPG (IMG:style_emoticons/default/smile.gif) . /Lars S I made mine so both are at the same opening at all times. Being so far apart and only joined with a small hose, making them progressive isn't an option but it might work with your setup. The only downside I've noticed is a sensitivity to slight input changes at very light throttle settings. |
AE354803 |
Jan 10 2014, 01:26 PM
Member Group: Members Posts: 232 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California |
Anybody tried double D-jet air boxes and TB before? (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1389339349.1.jpg) /Lars S I'm not sure but I think you may want to cut the cyl 1/2 runners so they are the same length as your 3/4 runners, you could then use the cutoff section of the runner to connect the 1/2 TB manifold to the 3/4 TB manifold? This should make your setup and flow to each cylinder bank more even. The way it is right now I would expect cylinders 3/4 to have higher flow than 1/2 (even if the 3/4 TB is closed and 1/2 TB wide open CYL 3/4 would still have the 3/4 TB manifold acting like an air reservoir while 1/2 would have to pull their air all the way through full length runners from the 1/2 TB manifold.) I don't have fuel injection on my Type IV but from an even flow perspective that should make things easier, neat project though |
Brian Mifsud |
Jan 10 2014, 04:11 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
So what do you gain with Double Throttle Bodies and Two Plenums?
I can understand that if I bumped the Stock Displacement of a 2.0, I'd get higher vacuum at the same RPM (making no changes to valve and cams). I'm assuming that this higher vacuum gets out of the range of the MAP sensor so the computer doensnt' get signal to send MORE gas? If I split the airflow into two seperate throttle bodies, I can see how Pressure-Drop or Vacuum would be reduced quite a bit for the same airflow since I'm flowing only to 2 cylinders. Is this the idea? |
Jan 10 2014, 08:55 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I am in love with this hack.
Please explain why and the benefits. I just see twin turbos, but please don't get side tracked on that. Rich |
larss |
Jan 10 2014, 11:25 PM
So what do you gain with Double Throttle Bodies and Two Plenums? To be honest - I dont know yet. This is an experiment I set up, could not resist to make it since I had all the stuff and it is a super easy modification (so far). The Engine is a 1911cc with standard 1,7 heads and std 1,7 D-jet, not started with the double arrangement yet. Its a street car, Im not looking for race performance. The theory is thet the larger displacement needs more air (and fuel) and hopefully the two 1,7 airboxes and TB's and can give some more air. Fiddeling with the MPS, CHT and fuel pressure will bring more fuel. I may have used a single 2,0 TB with manifolds instead if I had one. If I split the airflow into two seperate throttle bodies, I can see how Pressure-Drop or Vacuum would be reduced quite a bit for the same airflow since I'm flowing only to 2 cylinders. Yes lower vacuum sensed by the MPS means more fuel as far as I understand. /Lars S |
larss |
Jan 12 2014, 07:30 AM
Anybody tried double D-jet air boxes and TB before? (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1389339349.1.jpg) /Lars S I'm not sure but I think you may want to cut the cyl 1/2 runners so they are the same length as your 3/4 runners, you could then use the cutoff section of the runner to connect the 1/2 TB manifold to the 3/4 TB manifold? This should make your setup and flow to each cylinder bank more even. The way it is right now I would expect cylinders 3/4 to have higher flow than 1/2 (even if the 3/4 TB is closed and 1/2 TB wide open CYL 3/4 would still have the 3/4 TB manifold acting like an air reservoir while 1/2 would have to pull their air all the way through full length runners from the 1/2 TB manifold.) I don't have fuel injection on my Type IV but from an even flow perspective that should make things easier, neat project though Yes the arrangement is not balanced (yet). It was wery handy to use the original brackets for the left plenum so that one is in its original position. However it would not be to complicated to make the installation almost symmetrical. /Lars S |
ClayPerrine |
Jan 12 2014, 08:31 AM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Why not split two plenums down the middle at the seams, and weld the two half pieces together to make one plenum with two throttle body openings?
It would be simpler, and the intake runner lengths would not change. |
Jan 12 2014, 09:10 AM
Why not split two plenums down the middle at the seams, and weld the two half pieces together to make one plenum with two throttle body openings? It would be simpler, and the intake runner lengths would not change. More volume in the plenum is part of this solution. So adding that volume with two plenum a is one way of doing that. I am still curious as to why someone would do this? |
Chris Pincetich |
Jan 12 2014, 11:02 AM
larss |
Jan 12 2014, 11:11 AM
Why not split two plenums down the middle at the seams, and weld the two half pieces together to make one plenum with two throttle body openings? It would be simpler, and the intake runner lengths would not change. .... I am still curious as to why someone would do this? More cc's needs more air. /Lars s |
larss |
Jan 12 2014, 11:14 AM
Why not split two plenums down the middle at the seams, and weld the two half pieces together to make one plenum with two throttle body openings? It would be simpler, and the intake runner lengths would not change. Yes one combined plenum sounds like a good idea! /Lars S |
MrLeeS |
Jan 12 2014, 11:53 AM
Member Group: Members Posts: 62 Joined: 25-April 09 From: Albuquerque, NM Member No.: 10,300 Region Association: Southwest Region |
Neat idea, but I don't see any benefit in your case. The small increase in displacement, maintaining the same long restrictive intake runners, and I assume the stock fi cam make it a fun science experiment that will probably be a pita to tune with little to no benefit.
larss |
Jan 12 2014, 12:00 PM
Neat idea, but I don't see any benefit in your case. The small increase in displacement, maintaining the same long restrictive intake runners, and I assume the stock fi cam make it a fun science experiment that will probably be a pita to tune with little to no benefit. Thanks, Im afraid you might be right but I can't resist to do it. /Lars S |
AE354803 |
Jan 12 2014, 02:53 PM
Neat idea, but I don't see any benefit in your case. The small increase in displacement, maintaining the same long restrictive intake runners, and I assume the stock fi cam make it a fun science experiment that will probably be a pita to tune with little to no benefit. Thanks, Im afraid you might be right but I can't resist to do it. /Lars S If you move each TB close to the heads like you have on the 3/4 Cyl side the shorter runner and closer TB may help out? |
Lo-Fi Version | Time is now: 21st May 2024 - 01:07 AM |
