WTB cover piece below armrest, pass. side |
Peashooter |
Jan 10 2014, 07:33 PM
Member Group: Members Posts: 163 Joined: 17-December 11 From: SW Ohio Member No.: 13,903 Region Association: None |
I am looking for the triangle sized piece that screws on below the armrest for the passenger side door. I have a 1970 914...I'm not sure if all years were the same or if the earlier cars were different.
I would like to find one that is in solid shape, even if it needs to be recovered. Thanks, Bill |
GaroldShaffer |
Jan 10 2014, 07:57 PM
You bought another 914? Group: Benefactors Posts: 7,621 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I should have what you need. Let me check my stash. PM sent
Mike Fitton |
Jan 10 2014, 09:03 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
Milsha12 |
Jan 18 2014, 10:03 PM
Newbie Group: Members Posts: 2 Joined: 7-August 07 From: Sterling Heights, MI Member No.: 7,981 |
As far as I know (others can weigh in if I'm wrong)...
The earlier ones were made of a cardboard or fiberboard-like piece with vinyl covering. Later models had a piece that was fully plastic, but made to look like the vinyl covered early versions. Not sure when they switched...maybe '74. The pictured one at the link on the samba is the plastic version. From what I have seen, the benefit of the later ones is the mounting holes don't get torn out, so it's probably easier to find those in good shape. However, if you want originality for your 1970 car (and in my opinion, a better look), you want to find a nice early one. |
Lo-Fi Version | Time is now: 9th May 2024 - 09:08 PM |
