Grounding the battery., What's the proper way? |
Bob L. |
Jan 12 2014, 10:58 AM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I have just finished moving the battery to the front trunk. so far I have the ground cable bolted through a pre drilled hole in the front trunk. I scraped away some paint/coating to get to bare metal, for a good ground. So far it all seems to work fine. I just don't feel like I should leave it like that.
Is there a proper way to prepare the sheet metal/bolt/wire to prevent corrosion from the current or moisture? OR... should I just coat it over with a protectant spray now that it is done? Thanks, Bob. |
Lo-Fi Version | Time is now: 27th May 2024 - 02:44 AM |
