Valve covers, Engine mount bar, anything I should't powder coat? |
Steve73 |
Jan 12 2014, 03:31 PM
Photographer/Shade Tree Mechanic Group: Members Posts: 125 Joined: 2-July 11 From: Nashville Member No.: 13,269 Region Association: South East States |
I've already finished my engine tin in a semi gloss black, thinking about doing the above parts as well. Any opinions?
Gonna do the tin work above the push rod tubes as well as the push rod tubes. Stephen |
Steve73 |
Jan 13 2014, 10:53 AM
URY914 |
Jan 13 2014, 11:36 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,642 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
If you powder coat the engine bar you will have the prettist one in all the land. You'll have to post pics of it.
But why? (IMG:style_emoticons/default/confused24.gif) |
Jan 13 2014, 03:57 PM
Only thing I can think of is not to PC anything that has a precision or near-precision surface. So don't coat the area of the valve cover where the gasket goes. If you think clearance might be tight with your valve adjusting lugs, don't PC the inside of the cover at all. (It gets covered with oil anyway.)
If you subscribe to the notion that the valve covers dissipate a noticeable amount of heat from the oil, then don't coat them at all, unless the coating helps heat transfer. Probably don't coat the mounting holes for the engine mount bar or the ends of the mounting holes. The latter depends on how well the PC material (and your prep!) holds up to nut-and-bolt-and-washer pressure. No reason not to powder-coat the outsides of most things. Not a big reason to coat most of them--but whatever floats your boat! --DD |
Steve73 |
Jan 13 2014, 08:12 PM
If you powder coat the engine bar you will have the prettist one in all the land. You'll have to post pics of it. But why? (IMG:style_emoticons/default/confused24.gif) It will impress anyone who looks under it, that will mostly be me (IMG:style_emoticons/default/smile.gif) I don't think clearence or sealing will be an issue with the valve covers. The current ones are super grungy on the outside and anything at this point will look better. The pushrod tubes are a rusty mess as well, should I just paint them with a high temp silver paint instead? If the tubes get sandblasted i fear that they won't seal well on the end. |
krazykonrad |
Jan 13 2014, 10:18 PM
Senior Member Group: Members Posts: 1,126 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Just get some new tubes. By the time you clean and powder coat yours, you won't be far off in price.
My $0.02, Konrad |
Highland |
Jan 13 2014, 10:37 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I soaked my pushrod tubes in this stuff from Harbor Freight and it seem to remove the rust. I tried it in below 65 degree weather and didn't work very well until we got some warm SoCal winter weather.
http://www.harborfreight.com/1-quart-evapo...mover-96433.htm I then painted them with VHT high temp paint and baked them out in an old toaster oven. Figured the rust remover was worth the try for $9 with a 25% coupon before spending $80+ on new tubes. Engine is far from finished, so can't tell you how they're holding up. I had my large tins and valve covers powder coated just cause they needed sand blasting which would have cost as much as the powder coating which includes the clean-up. The shop I brought them to had a $75 minimum charge so I wish I were more organized and brought them more pieces. |
Steve73 |
Jan 13 2014, 11:01 PM
I soaked my pushrod tubes in this stuff from Harbor Freight and it seem to remove the rust. I tried it in below 65 degree weather and didn't work very well until we got some warm SoCal winter weather. http://www.harborfreight.com/1-quart-evapo...mover-96433.htm I then painted them with VHT high temp paint and baked them out in an old toaster oven. Figured the rust remover was worth the try for $9 with a 25% coupon before spending $80+ on new tubes. Engine is far from finished, so can't tell you how they're holding up. I had my large tins and valve covers powder coated just cause they needed sand blasting which would have cost as much as the powder coating which includes the clean-up. The shop I brought them to had a $75 minimum charge so I wish I were more organized and brought them more pieces. I think engine paint is all that's needed on these tubes, it's not as hot as exhaust parts. I do like the way you think. I made the mistake of having parts sandblasted months before they were powder coated, forget that let the shop do it all at once which is what that want to make sure it's blasted to the right texture and is clean of grease and rust. I may just hit the tubes with my wire wheel and see how they look. If there is some rust left I may treat them with my Ospro and let them be. Besides new gaskets is there a teflon paste or some other product that should be applied before I reinstall the tubes? I was thinking about having the heads redone but I think that new heads is actually the way to go. Don't really want to pay for that right now so i'll just run it for a while and overhaul it in the future if I still have it. More fun for me (IMG:style_emoticons/default/smile.gif) |
ConeDodger |
Jan 13 2014, 11:09 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
If you powder coat the engine bar you will have the prettist one in all the land. You'll have to post pics of it. But why? (IMG:style_emoticons/default/confused24.gif) No he won't. I did mine. (IMG:style_emoticons/default/happy11.gif) got my own blast cabinet and a friend in Sac with a powdercoating shop... |
ConeDodger |
Jan 13 2014, 11:14 PM
I powder coated the fan pulley and Mark found it screwed up the alignment of the fan IIRC. He fixed it. Don't do that... (IMG:style_emoticons/default/sad.gif)
Steve73 |
Jan 21 2014, 11:45 PM
If you powder coat the engine bar you will have the prettist one in all the land. You'll have to post pics of it. But why? (IMG:style_emoticons/default/confused24.gif) No he won't. I did mine. (IMG:style_emoticons/default/happy11.gif) got my own blast cabinet and a friend in Sac with a powdercoating shop... Valve Covers, Engine mount cross beam and tin work that goes under the push rod tubes are all nicely power coated. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:52 PM |
