| shuie |
Jan 12 2014, 09:18 PM
Member ![]() ![]() Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
Where does this attach on the pedal cluster? Over the pivot ball on crank? Does anyone have a pic? I don't see the spring at all in PET. I can see the holes in the side of my center tunnel for the other end of it.
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-2075-1389583130.1.jpg) TIA |
| wildman |
Jan 12 2014, 09:53 PM
Newbie ![]() Group: Members Posts: 34 Joined: 24-May 11 From: Oklahoma City, OK Member No.: 13,112 Region Association: Southwest Region |
I don't think that's a factory part, I haven't seen one on any of the cars i've worked on at least.
| Dave_Darling |
Jan 12 2014, 10:05 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,287 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
That doesn't go on or near the pedal cluster.
It probably goes between the throttle arm (on the throttle plate) and a flange on the plenum, or possibly onto another piece of sheet metal nearby. I seem to recall a long coil-spring going to the engine tin on my old 1.8 engine. --DD |
| shuie |
Jan 12 2014, 10:32 PM
Really? It was attached to the center tunnel of my 71. I at least thought I remembered having something similar on an early '70s 911. This is my first 914 and it was in pieces when I got it . The car must have just been modified at some point. Who knows. Oh well. Thanks again of the help.
| Cap'n Krusty |
Jan 12 2014, 10:41 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Nope. Not on a 914, nor ANY 911 or 912. Ever.
The Cap'n |
| WPEngels |
Jan 13 2014, 05:53 AM
Newbie ![]() Group: Members Posts: 18 Joined: 20-November 13 From: Netherlands Member No.: 16,678 Region Association: None |
I'm not sure but that looks like the spring that I threw away since I couldn't find where to put it. (IMG:style_emoticons/default/headbang.gif) Luckily, I got it out of the bin before that was emptied. Somewhere on this forum I found a picture of this spring.
I thinkit holds the cover of the compartment under the drivers armrest. I took the photo attached to this message. There is a plastic tube/cover around the spring. Wilbert Engels |
| partwerks |
Jan 13 2014, 07:20 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,618 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The one on the arm rest flap is too short, probably the throttle return spring?
Lo-Fi Version | Time is now: 7th November 2025 - 04:03 AM |
