LAST DAY- The coveted triangle window seals! Closes Feb 14th, GB $92 a set..+shipping. Yes left and right! ? $120 after |
Mikey914 |
Jan 16 2014, 12:54 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes, I've been working on these for awhile. The fist ones were copies of the best I could find, and not as good as OEM, I made then as cast molds using catalyzed rubber. Sometimes it didn't flow all the way as the pressure required to make these meant that I wound up throwing out about 1/2 of the ones I made. I cheated the formulation to make it flow better and found that didn't work as well.
The only choice was aluminum tooling. It can take the pressure and allow for using a compound that flows and and looks correct. Well I finally did it. I actually improved the little skinny part on the back edge of the seal so that it actually fills the little void in the indentation on the inside of the door. This is something the OEM current version does, but it's a little loose. So below is a picture of the OEM and one of my seals. Guess which one is mine. I'm posting in larger files so you can zoom in on the details. This is one of the big projects I've been trying to get off my plate for about 18 months. Attached thumbnail(s) |
Mikey914 |
Jan 16 2014, 12:55 AM
more
Mikey914 |
more
Mikey914 |
Jan 16 2014, 12:56 AM
more
Mikey914 |
of course more
Mikey914 |
Jan 16 2014, 12:57 AM
one more
CptTripps |
Jan 16 2014, 01:19 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Those look perfect. I'm in!
Mikey914 |
Jan 16 2014, 01:31 AM
Inside, inside, top and right are mine.
ConeDodger |
Jan 16 2014, 01:35 AM
Apex killer! Group: Members Posts: 23,589 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Do I have to??? (IMG:style_emoticons/default/biggrin.gif)
Niklas |
Jan 16 2014, 04:33 AM
Porsche 914 Sweden Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
3 sets for me.
walterolin |
Jan 16 2014, 07:10 AM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Early and late the same?
I'm in for one set, early. |
raw1298 |
Jan 16 2014, 07:17 AM
Senior Member Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California |
Nice.
914_teener |
Jan 16 2014, 07:26 AM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Wow......very cool....I am in for set Mark.
FourBlades |
Jan 16 2014, 08:42 AM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
How do you have time to make all these killer parts??? I still have a set of your last batch that I have not even installed yet... Let me put those on my car and then I can order the replacements. (IMG:style_emoticons/default/biggrin.gif) John |
ThePaintedMan |
Jan 16 2014, 08:58 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
(IMG:style_emoticons/default/piratenanner.gif) These are awesome Mark! I've been waiting for these to come down in price a little before ordering a set. They'll be on my next round of goodies to order from you for sure. Thanks for all of your hard work.
billh1963 |
Jan 16 2014, 08:59 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
I'm in for one set
no1uno |
Jan 16 2014, 09:04 AM
Member Group: Members Posts: 206 Joined: 2-December 10 From: Melbourne, FL Member No.: 12,448 Region Association: South East States |
I'll take a set.
mharmon |
Jan 16 2014, 09:33 AM
Member Group: Members Posts: 129 Joined: 1-November 06 From: Los Angeles Member No.: 7,133 |
I'm in for a set
Mikey914 |
Jan 16 2014, 10:48 AM
Mikey914 |
Jan 16 2014, 10:51 AM
How do you have time to make all these killer parts??? I still have a set of your last batch that I have not even installed yet... Let me put those on my car and then I can order the replacements. (IMG:style_emoticons/default/biggrin.gif) John These are the tip of the iceburg. I'm doing a ton of stuff for Stoddard too! It's how I have been able to afford to make the tooling for this and more new stuff. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:30 PM |
