Case to Head Studs, Any sealants |
Allan |
Jan 2 2005, 05:33 PM
I was starting to put the case to head studs back in and found that they go all the way into the case. What type of sealer should I use at the case side and does anyone know what the overall height of the studs from the case surface should be after they are installed?
Thanks |
ejm |
Jan 2 2005, 06:06 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,694 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Are you building a 6 or a 4? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Allan |
Jan 2 2005, 06:18 PM
2.0 four.
ejm |
Jan 2 2005, 07:16 PM
Stud length is more critical on a 6
Studs on a 2.0 out in the garage measures 5 1/2'" top, 7 7/16" bottom from the cyl seating surface...I'd use a little red loctite |
Allan |
Jan 2 2005, 07:35 PM
Thanks a bunch. Now I'm gonna put them in!
Lo-Fi Version | Time is now: 9th June 2024 - 06:38 PM |
