My midlife crisis, (rebuilding engine, sort of) |
mobymutt |
Jan 19 2014, 12:47 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I just picked up a 1974 1.8 (carb conversion). It has been parked in an unheated garage for about 3 years, and was supposedly running fine before that, although it wont' fire up now.
My plan is to get it running, drive it on nice summer weekends, and use the other 9 months of the year to fix it up. Never worked on a car before, so looking forward to joining the fun! I'll post some pictures as soon as I figure out how... |
gothspeed |
Jan 19 2014, 03:00 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
if the engine turns over ok .... first thing to do would be to check the valve adjustment, then disassemble / clean the carbs / fuel system, fuel pump, spark plugs and inner distributor components .... while you have the spark plugs out .... you can put a tiny bit of marvel mystery oil into the cylinders along with changing the oil ..... and ..... as was mentioned ..... mice nests ..... (IMG:style_emoticons/default/popcorn[1].gif)
Lo-Fi Version | Time is now: 15th May 2024 - 04:35 PM |
