My midlife crisis, (rebuilding engine, sort of) |
mobymutt |
Jan 19 2014, 12:47 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I just picked up a 1974 1.8 (carb conversion). It has been parked in an unheated garage for about 3 years, and was supposedly running fine before that, although it wont' fire up now.
My plan is to get it running, drive it on nice summer weekends, and use the other 9 months of the year to fix it up. Never worked on a car before, so looking forward to joining the fun! I'll post some pictures as soon as I figure out how... |
Dave_Darling |
Apr 25 2014, 03:41 PM
914 Idiot Group: Members Posts: 14,985 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Nope, the clutch pedal spring is installed to pull the pedal to the floorboard. The pic is correct.
The shift knob looks original, but the lever? Uhm, not so much. Rust around the pedal cluster can indicate a leaky master cylinder. Brake fluid will make the original plastic bushings in the pedal cluster swell and creak. The throttle pedals have a hinge inside the rubber. This can get rust (see: brake fluid leak) and will get sticky and crunchy and eventually wobbly. The 911 pedals are not identical but can be used as a replacement. --DD |
Lo-Fi Version | Time is now: 15th May 2024 - 05:14 AM |
