My midlife crisis, (rebuilding engine, sort of) |
mobymutt |
Jan 19 2014, 12:47 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I just picked up a 1974 1.8 (carb conversion). It has been parked in an unheated garage for about 3 years, and was supposedly running fine before that, although it wont' fire up now.
My plan is to get it running, drive it on nice summer weekends, and use the other 9 months of the year to fix it up. Never worked on a car before, so looking forward to joining the fun! I'll post some pictures as soon as I figure out how... |
mobymutt |
May 21 2014, 02:08 PM
Well, success! I was able to get the fresh air blower to work on the slow and medium speeds, which is good enough for now!
Now to put everything back together and see if it will pass inspection! |
bdstone914 |
May 21 2014, 03:03 PM
bdstone914 Group: Members Posts: 4,521 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Well, success! I was able to get the fresh air blower to work on the slow and medium speeds, which is good enough for now! Now to put everything back together and see if it will pass inspection! Having no Hi speed on the fan is often a problem on the control. The plastic melts and raises up keeping the slider contact from touching the board. You might be able to undo the bolt that holds the control and slide it out enough to access it. Will try to get a picture. Bruce Edit. This one is starting to melt. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 04:47 PM |
