boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
Kind of curious what the ratio is these days...
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,149 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Basically stock '74 2.0 w/djet. I bought the car 8 years ago and the PO had installed a Compufire unit. Rock solid reliable.
somd914 |
Member ![]() ![]() ![]() Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region ![]() |
Several years on a Pertronix - no issues and don't miss setting points...
saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,015 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Still running with points, bone stock 2.0 D-jet. I will probably go electronic at some point though.
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,815 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Points with an MSD box. Points never need adjusting even though Ive checked.
Woody |
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region ![]() |
Crane XR700 which has been flawless. I'll be going with a Mallory and an MSD 6al 2 with the 2414 I'm building.
Madswede |
Flat Out Driver ![]() ![]() ![]() Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains ![]() |
I don't mean to brag, but I've got electronic distributorless ignition, twin plug, managed by Megasquirt. (IMG:style_emoticons/default/shades.gif)
Oh who am I kidding? Of course I'm bragging. (IMG:style_emoticons/default/laugh.gif) It's still pretty effin' cool. |
falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
Another mad Swede that will be ditching Djet here aswell, will be using VEMS, Nira or MaxxEcu. (IMG:style_emoticons/default/piratenanner.gif)
Java2570 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest ![]() |
I've been using Pertronix for over 6 years in both my 914 and my VW Ghia when I had that. No issues whatsoever with the module. I think the main reason for going away from points was the quality of the points modules is terrible now. Bosch quality has really slipped in past years, it seems to be the trend lately.
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
Hot spark. Been using it for years without problems. Probably 50K miles
eyesright |
Member ![]() ![]() Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region ![]() |
I've been using Pertronix for over 6 years in both my 914 and my VW Ghia when I had that. No issues whatsoever with the module. I think the main reason for going away from points was the quality of the points modules is terrible now. Bosch quality has really slipped in past years, it seems to be the trend lately. I agree. '76 2.0 L stock DJet. I had three sets of points fail on me from different manufacturers...or at least suppliers/brands...by the cam follower wearing down quickly to where the points would no longer open significantly. I went with Pertronics Igniter II and even bought the hot coil, mostly because it was available from Pelican. The first set failed within 10 miles. It turned out to be the coil but I returned coil and module to Pelican for exchange with no problem. It was a bit of a pain because I was 800 miles from home, with 200 miles to go, on a cold, wet, Sunday evening and my only choice was to somehow get the failed points to open enough to run another 4 hours. (IMG:style_emoticons/default/wacko.gif) The rubber grommet on the module is too big for the entry hole in the distributor and I had to substitute a smaller one nor would the connecters fit thru the hole so I had to snip those off and solder/crimp on replacements. But the new ones have worked fine for several months now and they definitely improve pulling out from a stop. I did call Pertronics about the oil filled coil. I had noted here on the forum that oil filled coils are not happy when installed horizontally as on 914s but fine vertically as on Bugs. That didn't make sense if, as I suspect, all these OEM Bosch coils are oil filled. The Pertronics rep said there is no problem as long as the poles are on a horizontal plane keeping the windings equally covered with oil. The poles should not be installed on a vertical plane. |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,588 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,327 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
QUOTE Still running with points, bone stock 2.0 D-jet. I will probably go electronic at some point though. (IMG:style_emoticons/default/agree.gif) |
rmital |
Northeast optimist ![]() ![]() ![]() Group: Members Posts: 1,954 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 ![]() |
.......the quality of the points modules is terrible now. Bosch quality has really slipped in past years, it seems to be the trend lately. (IMG:style_emoticons/default/agree.gif) my only concern...but I do have a bunch (points) in reserve. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
MSD internals (IMG:style_emoticons/default/smile.gif)
Attached thumbnail(s) ![]() |
orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,758 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
So, either everybody is running electronic OR everyone who runs electronic ignition reads and contributes to this forum.
Paul |
boxsterfan |
So, either everybody is running electronic OR everyone who runs electronic ignition reads and contributes to this forum. Paul Maybe it is because nobody wants to buy a dwell meter? (IMG:style_emoticons/default/beer3.gif) I'm running Pertronix, but it was installed by PO. I probably should have a spare set of points in the car for the eventual failure, but I probably won't. Instead, when it happens, I'll end up having the car towed home and ordering another Pertronix. I think people who have experienced immediate failure (or short lifetime duration) of electronic iginitions simply got unlucky. No company can produce a product (at a reasonable cost) without some failure rates. Companies in Georgia excluded. (IMG:style_emoticons/default/av-943.gif) |
Eddie914 |
Unregistered ![]() |
OK ... I'll spoil the party.
3.2 liter six Points Condenser Permatune CD box 40 IDA 3C Carburetors No issues other than ethanol fuel separation. |
gunny |
Member ![]() ![]() Group: Members Posts: 205 Joined: 17-October 12 From: Madison Al Member No.: 15,051 Region Association: South East States ![]() |
1976 djet with points. Never had a problem with points.
dale73914 |
Member ![]() ![]() Group: Members Posts: 209 Joined: 15-September 11 From: Victoria, Australia Member No.: 13,562 Region Association: Australia and New Zealand ![]() |
errrr, ive had my car for 3 1/2 years and never looked.....
oops It still runs (IMG:style_emoticons/default/smile.gif) Might have a look tomorrow Dale |
Lo-Fi Version | Time is now: 30th July 2025 - 06:12 PM |
