Stainless heat exchangers, FS $390 shipped *** SOLD*** |
SpecialInt |
Jan 30 2014, 12:17 PM
Newbie Group: Members Posts: 6 Joined: 3-December 13 From: Maryland Member No.: 16,722 Region Association: None |
sportlicherFahrer |
Jan 30 2014, 01:30 PM
Nothing to see here. Group: Members Posts: 1,079 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Pics? May be interested...
pilothyer |
Jan 30 2014, 01:43 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Super Price for nearly new..........Plus the hanger.
SpecialInt |
Jan 30 2014, 03:46 PM
SpecialInt |
Jan 30 2014, 03:47 PM
kkid |
Jan 30 2014, 07:09 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
So are these 2.0 Heat Exchangers?
hot_shoe914 |
Jan 30 2014, 07:19 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Look like 1.7/1.8 to me, not 2.0.
(IMG:style_emoticons/default/confused24.gif) |
SpecialInt |
Jan 30 2014, 08:59 PM
The ad does not state that these are 2.0 exchangers. They are 1.8 or 1.7 but will work on a 2.0 with the correct bracket and muffler. The bracket is included. |
sportlicherFahrer |
Jan 30 2014, 09:03 PM
Was hoping these were of the 2.0 variation. Thank you, but I'll pass.
Rand |
Jan 30 2014, 09:09 PM
Hey Jim, just curious... Aren't they all the same.... I mean ID matters. Performance-wise. The brackets and all, but if he has those, why are you turned off by the non-2.0? Your brackets don't line up? That's an easy fix.
sportlicherFahrer |
Jan 30 2014, 09:15 PM
1.7/1.8 have the turn up at the end. I'd have to go buy another Triad muffler. Also "beefing" up my 2056 a bit, so performance matters as well. My 2.0 exchangers on my car currently are in nice shape, but I'd jump on 2.0 SSI's in good shape for the right price.
kkid |
Jan 30 2014, 09:35 PM
Got a pic of the bracket?
SpecialInt |
Jan 31 2014, 12:53 PM
bdstone914 |
Jan 31 2014, 02:14 PM
That is a 2.0l bracket but it will not work with the heat exchangers you have.
The longer one you describe is probably a 75-76 type. This is a 1.7-1.8 type. Bruce Attached thumbnail(s) |
SpecialInt |
Jan 31 2014, 02:24 PM
SpecialInt |
Feb 2 2014, 07:07 PM
$450 shipped no bracket.
RFoulds |
Feb 3 2014, 12:46 PM
Green Teen 66 Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
jimkelly |
Feb 3 2014, 01:00 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
can you post some pics that show the thickness of the rear flanges.
they appear to be regular steel? as some had. pls post pics of both bottoms and both tops. are they completely dent free? |
SpecialInt |
Feb 4 2014, 10:02 AM
can you post some pics that show the thickness of the rear flanges. they appear to be regular steel? as some had. pls post pics of both bottoms and both tops. are they completely dent free? I will post up some more pics in a bit. They have steel flanges that are in good shape. I have not leak tested them however when in use by me they worked well. If there is a procedure you would like me to carry out to test for leaks please advise and I will get it done ASAP. |
GaroldShaffer |
Feb 4 2014, 02:36 PM
can you post some pics that show the thickness of the rear flanges. they appear to be regular steel? as some had. pls post pics of both bottoms and both tops. are they completely dent free? I will post up some more pics in a bit. They have steel flanges that are in good shape. I have not leak tested them however when in use by me they worked well. If there is a procedure you would like me to carry out to test for leaks please advise and I will get it done ASAP. Simple leak test I do is seal off the end where muffler attaches (some rubber & wood bolted on) Then fill each tube with water. If water leaks out around the shield then they are junk because the tube has cracked inside the shield. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:37 AM |
