> 914World Classifieds Rules
> FS 1973 2.4 E 6 cylinder Porsche engine
john forbes
post Feb 5 2014, 02:09 PM
Black Forest Racing, John Forbes
It has:
New main bearings and a standard crank
New rod and intermittent bearings
New timing chains and guides
New updated chain tensioner kit, distributor with points eliminator
Turbo lower valve covers
It has the good oil pump
I will update the oil by-pass and it will have the correct pistons and springs to go with it.
The cylinders are new E aluminum finned, shaved on the bottom for more compression, pistons machined to match.
I’m installing S cams so it will be close to S engine specs. I will jet and change the ventures in the 40 mm Weber carbs to specs.
I’m sonic cleaning the case and all the parts. It will be cleaned, painted, sheet metal, alternator installed and fan shroud included. I will run and tune it on engine test stand, re-torque it and adjust valves so it’s a bolt in engine. All this for only $9500.
If you don't want the sheet metal , alternator or fan shroud then it's $8500. Assembled without the carbs it's $6500 and if you want to assemble it yourself it's only $5000. It's a 911/52, sn 6220030.
Call John 704-351-3304 or email john@blackforestracing.com
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
- Lo-Fi Version Time is now: 1st May 2025 - 03:46 AM
