Sheridan Rear Spoiler, Now with How-To instructions! |
tomeric914 |
Feb 5 2014, 07:20 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Direct link to the "How-To" part: http://www.914world.com/bbs2/index.php?s=&...t&p=2022462
I received my Sheridan Rear Spoiler today and WOW is it ever nice! It is a simple piece but by far the nicest piece of fiberglass I have ever purchased. To do it justice, what is the best way to mount it to the deck? Sure, I could run stainless TEK screws through it but what have others done? If you have pictures, please post! thanks |
Woody |
Feb 5 2014, 09:03 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Pics please. (IMG:style_emoticons/default/popcorn[1].gif)
Randal |
Feb 5 2014, 10:20 PM
I received my Sheridan Rear Spoiler today and WOW is it ever nice! It is a simple piece but by far the nicest piece of fiberglass I have ever purchased. To do it justice, what is the best way to mount it to the deck? Sure, I could run stainless TEK screws through it but what have others done? If you have pictures, please post! thanks Doesn't it have bolt protruding from the bottom? If not I'd use riv nuts. I can post a picture of mine if you like. |
campbellcj |
Feb 6 2014, 12:24 AM
I can't Re Member Group: Members Posts: 4,540 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Coincidentally I am about to install one too. I was planning to use either large aluminum or stainless rivets, or possibly those screws that tighten from both ends (forgot what they're called.)
I decided to get a 2nd lid so I will have one with the spoiler and one without. Partially for cosmetics - I think the car looks cleaner without - and partially because I would probably have to remove it for vintage racing. It never hurts to have spare fiberglass regardless. |
campbellcj |
Randal there are no holes or hardware in the one I have. Just fiberglass.
carr914 |
Feb 6 2014, 04:45 AM
Racer from Birth Group: Members Posts: 118,160 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I used Stainless Nuts & Bolts
tomeric914 |
Feb 6 2014, 08:13 AM
Doesn't it have bolt protruding from the bottom? If not I'd use riv nuts. I can post a picture of mine if you like. Yes, please post a pic of yours. There are no bolts protruding. O-ring, closed end rivnuts may be the best way to go to prevent any leaks into the trunk area. I'd want to back up each riv nut with a fender washer if possible. ...or possibly those screws that tighten from both ends (forgot what they're called.) Those are typically called binding rivets. Years ago they were used to bind pages of a book together. I used Stainless Nuts & Bolts I saw that. The screw pattern looks somewhat random. Was there a reason for that? |
tomeric914 |
Feb 6 2014, 08:17 AM
BTW, Roger made mine in black gelcoat at my request. It's so nice that I may just clear coat it.
bulitt |
Feb 6 2014, 12:18 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
How come the bolts are not equi-distant?
(IMG:http://www.914world.com/bbs2/uploads/post-1623-1391683521.jpg) |
Randal |
Feb 6 2014, 02:24 PM
[quote name='tomeric914' date='Feb 6 2014, 06:13 AM' post='1994236']
[quote name='Randal' post='1994087' date='Feb 5 2014, 11:20 PM'] Doesn't it have bolt protruding from the bottom? If not I'd use riv nuts. I can post a picture of mine if you like. [/quote] Yes, please post a pic of yours. There are no bolts protruding. O-ring, closed end rivnuts may be the best way to go to prevent any leaks into the trunk area. I'd want to back up each riv nut with a fender washer if possible. Couldn't find the picture I wanted to show you, but again Riv nuts work great. My mechanic made a small iron bar, with a hole in one end to use tightening up Riv nuts with a socket. Works good, especially with the larger riv nuts you will want to use. Please post a picture of the spoiler and also where it will be going so we can see both parts. |
tomeric914 |
Feb 6 2014, 03:06 PM
carr914 |
Feb 6 2014, 07:10 PM
How come the bolts are not equi-distant? (IMG:http://www.914world.com/bbs2/uploads/post-1623-1391683521.jpg) I have no Idea (IMG:style_emoticons/default/drunk.gif) |
tomeric914 |
Feb 6 2014, 07:48 PM
Randal |
Feb 14 2014, 10:05 AM
tomeric914 |
Apr 8 2014, 06:55 PM
Ok, finally mounted mine using rivnuts with a sealed shoulder, stainless 1/4-20 x 5/8" bolts and stainless bonded sealing washers.
Step 1 - make sure the trunk is properly aligned with equal gaps on both sides Step 2 - clamp in place and align spoiler evenly side to side Step 3 - mark spoiler for drilling. I drilled 1/2" from the upright portion of the spoiler in the center and at 1 foot increments to both sides. Drill through the spoiler into the trunk for perfect alignment. Step 4 - install rivnuts. It will help to drill all the way through with a 1/4" drill to allow the rivnut tool to fully extend for the holes right next to center. The outer holes will need to be drilled straight through full size and will slightly contact the rubber seal strip of the trunk. Step 5 - mount spoiler and enjoy! |
Randal |
Apr 8 2014, 10:35 PM
Ok, finally mounted mine using rivnuts with a sealed shoulder, stainless 1/4-20 x 5/8" bolts and stainless bonded sealing washers. Step 1 - make sure the trunk is properly aligned with equal gaps on both sides Step 2 - clamp in place and align spoiler evenly side to side Step 3 - mark spoiler for drilling. I drilled 1/2" from the upright portion of the spoiler in the center and at 1 foot increments to both sides. Drill through the spoiler into the trunk for perfect alignment. Step 4 - install rivnuts. It will help to drill all the way through with a 1/4" drill to allow the rivnut tool to fully extend for the holes right next to center. The outer holes will need to be drilled straight through full size and will slightly contact the rubber seal strip of the trunk. Step 5 - mount spoiler and enjoy! Nice! |
reds |
Oct 13 2016, 10:25 AM
Newbie Group: Members Posts: 1 Joined: 20-October 14 From: Maryland Member No.: 18,035 Region Association: MidAtlantic Region |
I am looking to purchase a Sheridan rear spoiler very soon. For those of you who purchased the 6” version, is visibility out the back a problem?
campbellcj |
Oct 13 2016, 11:49 AM
I honestly never even noticed any change in visibility...but it's not like visibility is that great to begin with especially with full rollcage/race seat/helmet/hans...
campbellcj |
Oct 14 2016, 12:16 PM
tomeric914 |
Oct 15 2016, 11:35 AM
Who looks out the back window? (IMG:style_emoticons/default/confused24.gif)
It does not obscure my view at all. I am looking to purchase a Sheridan rear spoiler very soon. For those of you who purchased the 6” version, is visibility out the back a problem? |
Lo-Fi Version | Time is now: 25th April 2024 - 04:54 PM |
