Injectors, Ebay |
Injectors, Ebay |
Ray Warren |
Jan 4 2005, 08:04 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
A good deal on some 2.0L injectors.
I have purchased from this guy before without any problems. Injectors |
Allan |
Jan 4 2005, 08:08 PM
Good deal if you could get them for that price. Save almost a c-note I think.
TheCabinetmaker |
Jan 4 2005, 08:57 PM
Retails at about $80.00 each I think. I'm gonna bid (after I check the part #)unless someone here really needs them worse than I do. If so, let me know, and I'll back off.
ccininjectormode |
CHAFF |
Jan 5 2005, 02:26 PM
Member Group: Members Posts: 167 Joined: 13-September 04 From: Regina, SK Member No.: 2,749 |
Anyone ever found a replacement injector that will work...possibly something not bosch?
-L |
Mark Henry |
Jan 5 2005, 02:44 PM
Heeheehee....
I know a few people who don't care for them... They won't screw you on ebay though. |
Steve Thacker |
Jan 5 2005, 04:22 PM
UMMMPH Yea Baby Yea ! UMMMPH Group: Members Posts: 1,089 Joined: 8-January 03 From: Pickerington, Ohio Member No.: 113 Region Association: Upper MidWest |
yep sure did and they are running in my 2.0. They are made by a company name Sorenson. Identical to the 2.0 factory units and they are only $45.00 ea. Advance Auto Parts has them. |
Mueller |
Jan 5 2005, 04:24 PM
are they brand new or rebuilt by Sorenson?? |
StratPlayer |
Jan 5 2005, 04:31 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Are these the injectors from advance auto parts that you are talking about?
http://www.partsamerica.com/PartDetails.as...ype=677&PTSet=A |
Steve Thacker |
Jan 6 2005, 04:05 AM
That unit I think is for the a 1.7, they also had ones for the 2.0. I'll have to get out a spare I bought to get the number off it. At the time "two years ago" they stocked ones for 2.0s. no core charge. Mueller they look brand spanking new to me. they have the sorenson name on them. I have had real good luck with the set I put in. They are just as good if not better than the OEM ones. IMHO. |
boxstr |
Jan 6 2005, 10:19 AM
Purchased these remanufactured injectors for a 74 1.8. I liked the price after FLAPS quoted $110.00 each.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMEWN%3AIT CLININJECTME |
martinef1963 |
Jan 6 2005, 10:26 AM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
Question - I have a 1.7 that was upgraded to a 1.9L - big bore kit - can I use these injectors?
Pros - Cons? thanks, |
Joe Bob |
Jan 6 2005, 10:35 AM
Can you use them? Sure...will they get the best out of the engine? Depends on how sensitive your seat of the pants is....but only a dyno run will tell you that for sure.
drgchapman |
Jan 6 2005, 11:33 AM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
I really need new injectors as well, I think. One of my 914's has a miss below 2800 rpm at feather throttle, worse when cold. I suspect a partially clogged injector??? Looking to have a spare set to send out to have cleaned and flow tested at RC engineering.
CHAFF |
Jan 6 2005, 12:18 PM
its looks like that set:
http://www.partsamerica.com/PartDetails.as...ype=677&PTSet=A cross references to the 1.7L bosch PN: OE #0280150009, 0280150009; Multi-Port Injection the 2.0L one is: PORSCHE 039 906 031 BOSCH 0 280 150 019 2.0L 1973 - 1974 Green plug FOUND ON PARTSAMERICA For vehicle: 1974 PORSCHE 914 H4 2.0 Liter FI (change) 5 parts found. Description Availability * Price Buy Niehoff Ignition 57513 Fuel Injector, New: Seal Kit Required; D-Jetronic; O.E. No. 039 906 031,039 906 031A 1 Year Limited Warranty Ships in 5 days Weight: 2.8 lbs. $61.99 Niehoff Ignition 49196 Fuel Injector, Remanufactured: Seal Kit Required; D-Jetronic 1 Year Limited Warranty Ships in 5 days Weight: 2.8 lbs. $54.99 $8.00 core Borg Warner 57513 Fuel Injector, New: Seal Kit Required, D-Jetronic, OE No: 039 906 031, 039 906 031A 1 Year Limited Warranty Ships in 2 days Weight: 2 lbs. $74.99 GP Sorensen 8001112N ; Multi-Port Injection 1 Year Replacement Warranty Ships in 1 day Weight: 0.3 lbs. $55.99 GP Sorensen 8001061N OE #0280150019; 914 Listing; Multi-Port Injection 1 Year Replacement Warranty sometimes I wish I lived in the USA...it sure would be a lot easier to buy parts! Good prices on this site too! -L |
Steve Thacker |
Jan 6 2005, 12:35 PM
Thats the deal! Thanks for looking deeper. Some days I'm about as useful as lipstick on a pig.
Lo-Fi Version | Time is now: 16th May 2024 - 06:22 AM |
