1974 1.8 or 2.0 |
1974 1.8 or 2.0 |
bajafreaks |
Feb 12 2014, 09:35 PM
Member Group: Members Posts: 73 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
The 74 I just bought doesn't have the original engine, how do I know if this car came with a 1.8 or 2.0 ??? vin#4742906720
Cap'n Krusty |
Feb 12 2014, 10:36 PM
The engine you think you have is substantially different from other Type 4 based engines, and it's unlikely to be in your car. Let's see a picture of the top of the engine .........
The Cap'n |
bajafreaks |
Feb 12 2014, 11:08 PM
JFJ914 |
Feb 13 2014, 09:34 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
The engine you think you have is substantially different from other Type 4 based engines, and it's unlikely to be in your car. Let's see a picture of the top of the engine ......... The Cap'n The number on the engine is CV0444076 and when I looked it up it stated 80-83 vanagon 2.0 See the red rectangle on the drivers sidewall? Is the emissions sticker under the red paint? Try to clean the sticker carefully, I used brake cleaner, and see what it says. |
Cap'n Krusty |
Feb 13 2014, 12:44 PM
The engine you think you have is substantially different from other Type 4 based engines, and it's unlikely to be in your car. Let's see a picture of the top of the engine ......... The Cap'n The number on the engine is CV0444076 and when I looked it up it stated 80-83 vanagon 2.0 See the red rectangle on the drivers sidewall? Is the emissions sticker under the red paint? Try to clean the sticker carefully, I used brake cleaner, and see what it says. It is, indeed, a Vanagon motor. Prone to meltdowns when the EGR system is disabled. In this case, removed. Probably be OK with carbs, probably not with FI. How do you add oil? Vanagons used a lower block mounted oil filler unit, which would interfere with the alternator and the tin. I see they solved the dipstick issue with that contraption sticking way up in the middle of the engine compartment. Interesting ................... The Cap'n |
Lo-Fi Version | Time is now: 19th April 2024 - 09:03 PM |
