Air Pressure Sensor, How to test |
Allan |
Jan 5 2005, 06:22 PM
Are these things supposed to hold a vacuum? My car was running pretty well when I pulled it out but I seem to remember seeing something on how to test.
Bleyseng |
Jan 5 2005, 06:58 PM
Take a vacuum tester and pump up to 15hg and wait 5 minutes. After 5 min is it still holding 15hg or how much has it leaked down???
Geoff |
jr91472 |
Jan 5 2005, 07:01 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
suck on it and then see if it will hold your tongue (you know, like a straw) (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) ..........no really...it will at least tell you if the diaphram is intact.
flame on..... (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) |
Bleyseng |
Jan 5 2005, 07:07 PM
You can't suck enough to tell!! unless, shoot I won't go there.....
Geoff (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
SLITS |
Jan 5 2005, 07:16 PM
See PBanders site on the D-Jet System.
I thought it was pump to 20 and then time the bleed down.....something like no more than 2" per minute. |
Allan |
Jan 5 2005, 07:51 PM
I did suck on it and couldn't even get a vacuum. Maybe it takes more suction than I can give (probably a good thing around here). I hope it's not bad.
Allan |
Jan 5 2005, 08:22 PM
I couldn't get the PBanders page to load but I found this on Rennlist. It says to blow into the sensor. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Pressure Sensor Located at a bracket near the battery, the pressure sensor is the single most important sensor in the fuel injection system. Consisting of an iron core surrounded by a pair of coils, mechanically connected to a thin metal diaphragm, this sensor measures the pressure at the intake air distributor relative to the ambient pressure (that is, it can correct for changes in altitude). It can fail in several ways. The coils can develop an electrical fault, or the diaphragm can leak. A defective sensor will often result in a very rich running condition. However, I have seen one fault resulting in the mixture becoming so lean that the engine wouldn't run. The coils can be tested by measuring the resistance between terminals #7 & # 15 (should be about 90 ohms) and between #8 & #10 (should be about 350 ohms). You can try blowing into the sensor to test the diaphragm. Although they carry different part numbers, the only difference between the 1.7L and 2.0L pressure sensors is calibration. I will describe how you can change this yourself later on. |
Cap'n Krusty |
Jan 5 2005, 08:26 PM
" 'Blow' is a figure of speech", he said. And, in this case, it won't tell you much. Gotta pull vacuum on it. You should be able to suck on it through a tight fitting hose, and stopper it with your tongue. If you can't pull any vacuum, it's likely toast.
Bleyseng |
Jan 5 2005, 08:38 PM
You can pull a really weak vacuum on it with sucking on it but if the diaphram is cracked then it will seem to hold a vacuum.
Test it with a mittyvac like I said to 15hg to find out. We test them at 15hg cuz thats what you are supposed to pull at idle. It should hold that for 5 minutes without bleeding down. If it does bleed down its got big problems. I have fixed/repaired about 20 of those darn things for 2.0l motors. Geoff |
Allan |
Jan 5 2005, 09:45 PM
I'll try and get one of our instrumentation techs to test it tomorrow. I'll report on the results.
DJsRepS |
Jan 6 2005, 05:10 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
If you pull vac by mouth and cap it by toung and cant get it to hold your toung with the vac you made its toast. If it does hold your toung then buy the Mightyvac and do a real test. Tool at Sears or Flaps $25-$45. Good for checking the vac adv on the dist as well.
Bleyseng |
Jan 6 2005, 12:35 PM
pic of the test
Allan |
Jan 6 2005, 12:46 PM
Thanks a ton, I think its done. When I suck on it I can hear air going through it. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Just another freekin cost.
SLITS |
Jan 6 2005, 01:14 PM
Allan |
Jan 6 2005, 01:38 PM
Thanks for the link Ron. I'm sure it's bad. Someone has been playing with it as well. The seal for the adjustment is gone as well as the cover.
SLITS |
Jan 6 2005, 01:43 PM
Links work perfectly for me.
If the seal is gone off the adjustment screw, someone has screwed with it. Which one do you need or should I ask what Bosch OEM is on yours? |
Allan |
Jan 6 2005, 02:05 PM
P/N: 0280100043
Bleyseng |
Jan 6 2005, 02:17 PM
is it still riveted together or screwed??
Allan |
Jan 6 2005, 02:23 PM
Still got the rivets in it.
Bleyseng |
Jan 6 2005, 03:44 PM
Well, my bets the diaphram is cracked then.
Geoff |
Lo-Fi Version | Time is now: 28th April 2024 - 12:54 PM |
