Triangle window seal installPic of late directions for both, How to - tools needed - other items |
Mikey914 |
Feb 17 2014, 12:27 AM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
First off I want to explain some of the photos. Pictures from my website have been showing up on other websites (9xauto), and I don't mind sharing info just not having what I've done show up on other commercial websites. I'm putting together an instructions for those that need it that by from my website, so it will be available on the site too.
Tool list - #2 Phillips screwdriver 10mm socket 13mm socket 6" extender for ratchet ratchet wrench 3/8? 13mm box wrench #4 standard screwdriver Wooden block and hammer Optional items to look at "while you are there" The Outer door fuzzy is difficult to access, you will be able to swap these out during this process. I do make the aluminum strips for early and late doors as well as the rollers for both Door handle isolators - If you need to swap out the seals on the door handles, this process will allow you to have more access. The door cam can be changed out at the same time. Locks can be rekeyed if needed and the door lock bushings replaced. Window rollers, both the early and late have rollers that are replaceable. The late doors have fuzzy strips that run vertical in the front and rear window guides, this is a good time to replace these too. The early door has rollers in the front track, the rear track has a plastic guide that runs up and down in the back track. The door stay is easily reached with the door panel removed. You can replace the rollers, springs, and the strap easily. The unit has a pin that holds it to the body, and 2 -10mm bolts hold the unit in. The fuzzy on the inside of the window can be replaced easily with the door panel off. Lastly the door end caps can be replaced at this time also. First off remove the door pockets, and plastic door handle cups. This will allow the door panel to be removed. Attached thumbnail(s) |
Mikey914 |
Feb 17 2014, 02:43 AM
You can then install the inner door fuzzy and the door panel
eyecolor |
Feb 18 2014, 08:45 PM
Eyecolor Group: Members Posts: 80 Joined: 15-August 08 From: Wilmington,DE Member No.: 9,425 Region Association: None |
You can then install the inner door fuzzy and the door panel Fantastic Mark Thanks How do you attach the rubber scraper after you have the rolling window re-inserted ? I've been trying to get the window in afterwards since I couldn't get it to slide though the gap space in the aluminum top. George O. |
Mikey914 |
Feb 19 2014, 12:35 AM
You can then install the inner door fuzzy and the door panel Fantastic Mark Thanks How do you attach the rubber scraper after you have the rolling window re-inserted ? I've been trying to get the window in afterwards since I couldn't get it to slide though the gap space in the aluminum top. George O. I can only speak for the late, but the key is getting the window regulator out of the way so you can maneuver the window. Also you can't get it in with the rear track in. if its a late just follow the order above. |
Lo-Fi Version | Time is now: 13th May 2024 - 07:37 AM |
