stray wire, connection point |
rhodyguy |
May 28 2003, 06:45 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,042 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
some wires come up through the dr side engine tin. one group (3) a red,green,brown plugs into the relay board. the other, a somewhat heavy red one, is the mystery. does it go to the starter or what? the seal arrived, engine's in.
kevin |
Brad Roberts |
May 28 2003, 09:41 AM
To the starter. Its the chargeback wire from the Alt. Pass it thru the grommet that your yellow starter wire passes thru. Put it on the same M6 stud that the battery wire is on.
Go baby !! B |
Lo-Fi Version | Time is now: 29th March 2024 - 06:04 AM |
