2.4L supercharged,electromotive FI, worth? |
DougC |
Jan 6 2005, 10:42 AM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
Found an engine listed as 2.4L with a Paxton supercharged Porsche engine and electromotive programmable FI and ignition. Low miles, excellent condition. I'll try to talk to the owner this evening, but I know nothing else about the engine. I assume it's a 6, right..what else is obvious and should be asked? What kind of money might this set up be worth? Would it be a good engine for a 6 conversion using stock tranny?
Doug C |
Root_Werks |
Jan 6 2005, 10:47 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I know they make the supercharger kits for 911 engines. I would think this to be a six and yeah, a 901 should hand the hp okay as long as you don't slam 1st. Wonder what hp it puts out? Sounds pretty dang cool to me! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
jd74914 |
Jan 6 2005, 10:55 AM
Learn something everyday. I didn't know that paxton makes kits for 6 cylinders. My friends uncle has a paxton kit on on his stang, with it he can smoke his tires at 60mph, of course he has some other engine mods (car has been dynoed @ 580hp)
Check out the engine. It sounds wicked cool (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Ferg |
Jan 6 2005, 11:22 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Yeah, sounds cool, I would also like to know what you have found out, but FYI I have seen this kit on a 911 and I think clearance is going to be a huge issure for a 914. He had a turbo tail, and it still needed modifying.
Ferg. |
jd74914 |
Jan 6 2005, 11:24 AM
Any car can be seriously modified (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
look at this car supercharged v8 Out of curiousity, is that guy a member here? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
DougC |
Jan 6 2005, 11:28 AM
The clearance issue because of the supercharger? Wonder what the resale value of this paxton would be if I decided to forgo it and keep the electromotive FI and ignition on the 2.4L. Is this older, smaller engine even worth while for a conversion (assuming stock rebuild or in excellent condition)? Guess that mostly depends what kind of money the guy wants, so what price range would make it a viable consideration?
Doug C |
Mueller |
Jan 6 2005, 11:43 AM
I'm betting that Paxton didn't make a kit, you can buy just the supercharger and install it on anything you want (like a lawn mower if you got really thick grass (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ) Doug, I'd have to guess that it's worth in the $3K to $5K range depending on the condition of the motor....figure $800 to $1000 for the supercharger, $500 to $1500 for the electromotive (really depends on how old and what model)...sounds neat, keep us updated (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
DougC |
Jan 6 2005, 02:34 PM
You know, looking at this closer it's probably a 2.4L Type4, is that possible for a reliable engine? (read daily driver)
Doug C |
Root_Werks |
Jan 6 2005, 02:57 PM
All depends on how/who built the engine. Got any pictures of it?
nebreitling |
Jan 6 2005, 04:05 PM
not going the V8 route?
if this is a Type-4, i'd be very dubious of it unless it was built by a reputable builder. unlikely to be very reliable otherwise. sounds very interesting in any case. |
DougC |
Jan 6 2005, 04:53 PM
No pictures of it yet, been waiting for them most of the day.. Will post Monday if I have some. Will be away from computer on Friday (b-day).
Nathan- I haven't completely decided one way or the other about which engine will end up in this car, just trying to way all my options - don't want to rush into anything. This thing is being offered at "best offer" or "make offer" can't remember. So I'm trying to figure out some numbers. Doug C |
DougC |
Jan 28 2005, 10:38 AM
OK, I got some pictures.. just wondering if this could ever be a depenable engine, even a 2.4L TypeIV without the supercharger? What do ya'll think?
Doug C Attached thumbnail(s) |
DougC |
Jan 28 2005, 10:39 AM
Another...
DougC |
Last one..
DougC |
Jan 28 2005, 10:41 AM
I haven't talked to the owner but my first question was gonna be "Will the engine lid even come close to closing?"..
Doug C |
Reiche |
Jan 28 2005, 11:10 AM
Member Group: Members Posts: 169 Joined: 13-October 04 From: Vista, CA Member No.: 2,934 |
I doubt it has ever run. Look at the intake pipe between the supercharger and TB. Looks like it is folded in the middle.
Even if it runs, I say Pull the pin and throw! That engine will run HOT HOT HOT. It might give you a chance to max out a CHT (if you can actually keep the heads on.) 1. Looks like homemade "type 1" under-cylinder tins in pic #2. Unless you have a DTM, those will not cool better than the stock tins. HOT 2. It looks like they chopped off the front of the air plenum to the 1-2 side to make clearance for the drive belt. Reduced air flow=HOTT 3. 2.4 liter t4 means it most likely has 103mm cylinders. I see a little rust on them so not Nickies. HOTTT 4. Extra heat from the pressurized intake air. HOTTTT That engine might be good for 1/4 mile passes, but for daily or track driving, no way. |
DougC |
Jan 28 2005, 11:26 AM
Yeah, I kinda figured some of that as well. Being sold as "make offer" so I was thinking about removing the Paxton (reselling it) and running it like that. But I'm not really looking for an engine that will have a tendency to run hot.
Doug C |
Mueller |
Jan 28 2005, 11:36 AM
offer him $500 for it....I'll give you a couple hundred for the supercharger (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Ferg |
Jan 28 2005, 11:39 AM
Ohh I see... I was thinking it was a 911 motor when i made the comments about clearing the lid, that looks like it may fit.
Ferg. |
Bleyseng |
Jan 28 2005, 11:40 AM
Guys have run the 103's cast iron for years. You will need to run a oil cooler with them plus they suffer from head leaks. Make good power thou.
$500 motor to me. junk the supercharger |
Lo-Fi Version | Time is now: 17th May 2024 - 06:56 PM |
