five bolt conversion studs, Wheel studs wanted |
pete-stevers |
Jan 6 2005, 05:28 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
lookin for 53-56mm studs for a rear five bolt conversion on my brother Gregs car, just lookin for the studs... reccomendation on mail order place...Gpr??
Cheers (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) steve |
TheCabinetmaker |
Jan 6 2005, 05:56 PM
skline |
Jan 6 2005, 06:00 PM
All I saw there were bolts, not studs, he is looking for the studs I think. I have a full set of studs somewhere here, let me see if I can find them. I know I had enough for a full rear conversion. They were new too. I bought them on the bay about a year or so ago and they are still in the bag. I had them out at D&G last time and before they sold, I changed my mind and decided to keep them for some reason. Since I cant remember why now, maybe I will let them go. |
TheCabinetmaker |
Jan 6 2005, 06:08 PM
Sorry about that. I have a site does studs too, but can't find it now. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Joe Bob |
Jan 6 2005, 06:18 PM
If that's stock size...I have a set of 20....used but serviceable.
nsyr |
Jan 6 2005, 08:49 PM
Because I Can Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
try smartracingproducts.com i believe they have 57mm for 4.20 a piece
Eric_Shea |
Jan 7 2005, 10:32 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Factory Verbus sizes are 45mm then 52mm. If you want to race with stock Fuchs you'll need open lug nuts and 74mm studs (allows the thread to stick out 14mm past the nut. PCA rules.) If you plan on using spacers beyond that add accordingly.
Call Garrity at Motorsport and tell him I sent you. He has some 52mm's in stock for the best prices I've found. Believe it or not, the shorter ones (Verbus) tend to be more expensive because not too many people move in that direction. When they restud a 911 for a race application it's always with a longer stud: 801-487-6733 Most studs are fine if they are installed properly. The advantage Verbus has is full engagement on the threads (the run the length of the stud). |
KenH |
Jan 7 2005, 11:33 AM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
Be SURE and check the studs "theaded length" before you install them. Some studs do not have enough thread length to allow the lug nut to fully thighten.
Ken |
groot |
Jan 7 2005, 03:12 PM
Dis member Group: Members Posts: 894 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
I've had decent luck with these studs. I have had trouble with the wheel nuts from this place. They had a ridge that didn't seat to me wheels, so I had to grind it down.
PAP-Parts Website |
Dr Evil |
Jan 7 2005, 05:12 PM
I got a set a Napa for $30 US. If you go to your local auto store they will have several different lengths and types.
HTH |
Lo-Fi Version | Time is now: 28th April 2024 - 10:06 AM |
