Dry film coatings for engines and wear surfaces, New parts and Reproccesing good used beaings |
Mark Henry |
Feb 28 2014, 08:34 AM
Starting to do DFL (Dry Film Coating)
http://en.wikipedia.org/wiki/Dry_lubricant Ever pull apart an engine and you look at the bearings and say to yourself "those look good, I bet I could reuse them..." but you don't because the are stained or have the odd speck in them? Well these puppies are getting expensive and some are hard to find. For the most part you don't need expensive measuring tools to figure this out, you just need eyeballs and fingernails. If it has obvious physical damage, wear through, pitting, material missing or large scratches you can catch your fingernails on, then sorry you need new bearings. Minor scratches down the middle that you barely catch a nail on may be OK. Also look at the backs, loose bearings will "walk" scoring the back. Again stains are OK, physical damage is not. Also when you remove the bearing does it just fall out (not good) or does it still hold itself in the saddle (good sign) and you have to wiggle it out. On Porsche 911 I'd say 9 out of 10 of the #8 bearings can be reprocessed. Used main bearing set (IMG:http://www.914world.com/bbs2/uploads/post-26-1393378175.jpg) New full bearing set (IMG:http://www.914world.com/bbs2/uploads/post-26-1393428146.jpg) used intemediate bearings before (IMG:http://www.914world.com/bbs2/uploads/post-26-1393529753.jpg) after (IMG:http://www.914world.com/bbs2/uploads/post-26-1393529779.jpg) 3.2 set before, minor scratches, 3 deeper scratches but still within spec. before (IMG:http://www.914world.com/bbs2/uploads/post-26-1393530486.jpg) after (IMG:http://www.914world.com/bbs2/uploads/post-26-1393594831.jpg) Close up pic's of the 3 worst from that set (IMG:http://www.914world.com/bbs2/uploads/post-26-1393594792.jpg) Not offering this on type 4 bearings (except I will do the steel backed split middle) at this time. This may change once I test a process. Piston skirts and ceramic piston coatings coming soon. Inspect and process full 911 engine bearings set (main, #8, rod and intermediate bearings, new or used) $175 Turn around 2-3 days. |
Mark Henry |
Feb 28 2014, 08:54 AM
Reprocessed #8 bearings, two are 3.0- and one is a 2.0-2.7
One of the 3.0 was within spec, but IMO a hair loose, the DFL slightly tightened up the tolerance. The DFL at the most adds .0005 (0.01mm) and this can reduced by polishing with a soft cloth. This takes a quite while to do, but is safer than using a green scotch bright pad. Top set of rod bearings are used 3.2 and the middle set are used 2.7 Attached image(s) |
Mark Henry |
Mar 3 2014, 07:33 AM
Pistons with DFL skirts and ceramic tops.
Theses have a fair bit of prep labour. Attached image(s) |
Harpo |
Mar 22 2014, 11:19 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Very interesting Mark,
Do these "wear in" and eliminate piston slap? This looks like it might be applied via power coating? One of my designers @ work has a neighbor who is supposedly powercoating superchargers for Eaton with a wear in low friction coating. Thanks David |
Mark Henry |
Mar 22 2014, 11:28 PM
I s sort of like powder coating but you don't need the electrical charge on the part. It is a baked finish.
It can increase the tolerance slightly, but by burnishing you can make it very sight. It won't eliminate piston slap from a part with excessive tolerances, It will help the skirt slip in the bore better. The coatings, besides being a dry film lube, wick the oil or grease to the face of it's surface. |
puffinator |
Mar 23 2014, 08:00 AM
Member Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
I s sort of like powder coating but you don't need the electrical charge on the part. It is a baked finish. It can increase the tolerance slightly, but by burnishing you can make it very sight. It won't eliminate piston slap from a part with excessive tolerances, It will help the skirt slip in the bore better. The coatings, besides being a dry film lube, wick the oil or grease to the face of it's surface. What is the additional thickness of the film? I just tore down a -6 and bearings look very good. |
Mark Henry |
Mar 24 2014, 09:47 AM
I s sort of like powder coating but you don't need the electrical charge on the part. It is a baked finish. It can increase the tolerance slightly, but by burnishing you can make it very sight. It won't eliminate piston slap from a part with excessive tolerances, It will help the skirt slip in the bore better. The coatings, besides being a dry film lube, wick the oil or grease to the face of it's surface. What is the additional thickness of the film? I just tore down a -6 and bearings look very good. When burnished I have a hard time reading it, literature says .0002 To be safe on a bearing I'll say since it's double about .0005" or .01mm. You can easily burnish it more if needed but the coating is getting pretty thin. On a used bearing and crank the extra .0005 is probably a good thing. BTW my 3.0 crank is good used standard, rods were done to the tight end of the spec and I only very lightly burnished the bearings with a soft cotton cloth. The bearings feel smooth as silk. |
puffinator |
Mar 24 2014, 10:02 AM
I s sort of like powder coating but you don't need the electrical charge on the part. It is a baked finish. It can increase the tolerance slightly, but by burnishing you can make it very sight. It won't eliminate piston slap from a part with excessive tolerances, It will help the skirt slip in the bore better. The coatings, besides being a dry film lube, wick the oil or grease to the face of it's surface. What is the additional thickness of the film? I just tore down a -6 and bearings look very good. When burnished I have a hard time reading it, literature says .0002 To be safe on a bearing I'll say since it's double about .0005" or .01mm. You can easily burnish it more if needed but the coating is getting pretty thin. On a used bearing and crank the extra .0005 is probably a good thing. BTW my 3.0 crank is good used standard, rods were done to the tight end of the spec and I only very lightly burnished the bearings with a soft cotton cloth. The bearings feel smooth as silk. Did you use Calico Coatings to do the work? |
Lo-Fi Version | Time is now: 18th May 2024 - 02:08 PM |
