Engine Purchase |
Engine Purchase |
john914somers |
Mar 12 2014, 08:34 PM
Member Group: Members Posts: 59 Joined: 24-January 12 From: sacramento Member No.: 14,051 Region Association: Northern California |
I'm calling on my 914 brothers for their valued opinions. Please help! I'm looking to buy a 3.6 vario-ram 3.6L motor for my 914 and I was wondering what you guys think about this? The company I'm looking to buy the engine from will not provide any compression check data, they say they just won't do it. But they will provide leak down check info. This engine is pretty pricey and I was wondering if not receiving the compression check data would be a deterant for you guys in buying this engine. Thanks a ton!
Mar 12 2014, 08:57 PM
914-6 GT in waiting Group: Members Posts: 19,245 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
why would you ever spend a big chunk of cash on something that makes you nervous? I would find another engine. they're not rare.
brant |
Mar 12 2014, 09:08 PM
914 Wizard Group: Members Posts: 11,616 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Who is the seller?
Matt Romanowski |
Mar 12 2014, 09:57 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
If the motor is out of a car, it's easy to do the leak down and much harder/impossible for the compression test.
Woody |
Mar 13 2014, 06:19 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
(IMG:style_emoticons/default/agree.gif) You would have to fit a flywheel, transmission, and starter. I value leakdown numbers quite a bit more than compression numbers.
mrbubblehead |
Mar 13 2014, 09:16 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
plus the engine shouldnt the engine be hot for a compression test?
john914somers |
Mar 13 2014, 10:52 PM
Woody |
Mar 14 2014, 06:18 AM
Chris Pincetich |
Mar 14 2014, 01:41 PM
Many CA suppliers provide 30 day grace periods to return a used engine. When I bought a TIV this way from EASY we had it installed and running within days, so lots of time to make sure it performed to spec. (IMG:style_emoticons/default/beerchug.gif)
ConeDodger |
Mar 14 2014, 08:47 PM
Apex killer! Group: Members Posts: 23,570 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Plus, a Varioram takes a bit of cutting to fit a 914...
Most of the parts houses will extend the 30 day guarantee if you tell them it will be a while before you get it in. Leak down should be fine... |
sixnotfour |
Mar 14 2014, 09:10 PM
914 Wizard Group: Members Posts: 10,414 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE But they will provide leak down check info that is better info, what's the numbers and mileage ?? |
john914somers |
Mar 14 2014, 11:33 PM
The seller is LA Dismantlers. The engine is still in the car and they offered it up to me to drive, which I will. The engine has 61,000 miles and the leak down numbers are 3-4%...pretty good if that's true.
ConeDodger |
Mar 15 2014, 12:05 AM
Search member PRS9146 and read the story of his 3.6 install. He bought his at LA Auto as well. Got them to extend the warranty until 30 days after he put it in. Similar miles, needed valve guides or job, and was only running on one distributor.
john914somers |
Mar 15 2014, 11:33 AM
Search member PRS9146 and read the story of his 3.6 install. He bought his at LA Auto as well. Got them to extend the warranty until 30 days after he put it in. Similar miles, needed valve guides or job, and was only running on one distributor. That's great advice! Thanks cone dodger |
0396 |
Mar 15 2014, 11:39 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
The seller is LA Dismantlers. The engine is still in the car and they offered it up to me to drive, which I will. The engine has 61,000 miles and the leak down numbers are 3-4%...pretty good if that's true. I would do your search on LA Dismantler. Make sure you get what they promise in writing. I have dreams of doing what your going to do. I see them at the local Porsche meets and they will tell you any thing you want to hear. I simply look at them and just think to myself...now I was not born yesterday - but the day before. Good luck on this journey....post when your done. |
Lo-Fi Version | Time is now: 30th April 2024 - 01:31 AM |
