| SteveL |
Mar 13 2014, 03:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 665 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None
I hit the key, and she cranks the starter a bit slow for a couple of turns then dies out. Acts exactly like a low battery.
Battery is new (1 month old). The car has not been driven since the new battery was put in, but it was started several times, and allowed to run a while. At first it cranked over just fine as you would expect with a brand new battery. Last week, the slow crank and die started. Charged battery, same thing. Brought battery to Interstate, they tested it and said it was fine. Cleaned all major connections - battery post connections, trans ground strap, battery ground to body, battery cable connection at starter. No improvement. I do have a starter relay installed, it has been there for many years. Help Please! I stumped. |
| dlee6204 |
Mar 13 2014, 03:59 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
Have you checked to see if your alternator is charging when the car is running?
| SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,369 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Check your tranny ground strap ...
(IMG:style_emoticons/default/shades.gif) EDIT: Saw that you did, alternator check is next. |
| SteveL |
Mar 13 2014, 04:12 PM
Check your tranny ground strap ... (IMG:style_emoticons/default/shades.gif) EDIT: Saw that you did, alternator check is next. I charged the battery fully. No difference. Or are you saying that an alternator issue can cause a voltage drain? |
| Dave_Darling |
Mar 13 2014, 05:46 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,298 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
You still have bad connections somewhere.
Try running a ground wire from the battery directly to the case of the starter. A nice FAT one. Does that help? Then something in the regular ground path is not right. You could also have a corroded battery (+) cable. --DD |
| Cap'n Krusty |
Mar 13 2014, 06:37 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Might wanna have an amp draw test done on the car. Could be a HUGE draw within the starter. I've also seen starters shorted internally that sucked a battery down in a matter of minutes.
The Cap'n |
| SteveL |
Mar 13 2014, 08:47 PM
OK - I used heavy duty jumper cables. Body of starter to battery ground post. No difference. Battery positive to positive log on the solenoid. No difference.
Voltmeter on the + and - terminals - 12.53 volts. Turn key and crank starter - goes down to 10.3 volts. Is that normal, or bad battery? Thanks again. This is driving me nuts. Snow is finally melting and I want to actually drive it this year! |
| r_towle |
Mar 13 2014, 08:50 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Starter
It lasted 40 years, be happy. |
| TheCabinetmaker |
Mar 13 2014, 08:55 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,358 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Jumper cables won't do it. You need a large wire fastened securely. remove and clean the starter connections. Then remove starter an take it to a local starter repair ship
| Bills914-4 |
Mar 14 2014, 05:37 AM
Member ![]() ![]() Group: Members Posts: 313 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
It seems like something binding or startermotor is dying , just for the hell of it , take the 4 spark plugs out and see if it rotates any differently ,also maybe by pass the key
with a jumper wire at the starter just to see if it rotates any differently . The starter on my car was acting up awhile back , I took the starter out and half apart to clean & lubricate , I also installed a relay under the dash , made a big difference , Bill D. |
| sfrenck |
Mar 14 2014, 11:24 AM
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region
Starter It lasted 40 years, be happy. (IMG:style_emoticons/default/agree.gif) I did troubleshooting on my car being hard to start until one day the starter stopped working all together. I was amazed how quickly it turned over once I replaced the starter. |
| Tom |
Mar 14 2014, 11:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Sounds like the starter may be going bad. The brushes in the starter are carbon and the commutator eats the brushes over the years. The resulting dust acts like a resistor and less voltage/current gets to the motor part of the starter. Sometimes disassembling and blowing out with air will help. If it is too oily/greasy, them more is needed to clean the dust out.
Tom |
| ConeDodger |
Mar 14 2014, 11:56 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,257 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Jack up the oil fill plug on the top of the motor and run a new car under it... (IMG:style_emoticons/default/lol-2.gif)
Or, find out what that starter is drawing. Assuming your ground is good and the battery is charged, you have a problem in the circuit to the starter or the starter... (IMG:style_emoticons/default/biggrin.gif) |
| stugray |
Mar 14 2014, 03:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE Or, find out what that starter is drawing. That is difficult to do as most of the current meters us "non-professional" electricians have cannot measure above ~10 Amps. |
| SteveL |
Mar 14 2014, 04:42 PM
I pulled the starter.
NAPA said they had a Bosch SR17x in stock. Went to pick it up, and it is the SR15x. All the books say it is a compatible replacement, but it is a LOT smaller. All other local places have rebuild versions of the Sr15x too. Anybody know anything about them? Will it work? Is is weaker? |
| stugray |
Mar 14 2014, 05:03 PM
I bought the high torque starter on ebay.
Seems to work good, but I've only started the car ~50 times since i installed it. They are much smaller than stock |
| Dave_Darling |
Mar 14 2014, 06:23 PM
| SteveL |
Mar 25 2014, 07:00 AM
Put in new starter, and it cranks faster than I can remember in a LOOOONG time.
WOW, what a difference. I've never seen a starter fail this way. It has always been either nothing from the starter at all, or really bad noises, but not slow crank. I wonder if a lot of the hot start issues are really starters beginning to go out, so they need extra power to spin? Thanks everyone for the advice. Now I just need to get the heat exchangers connected to the warm air pipes, hook up the flapper vales to the new cables, and adjust the driver window so it actually seals to the top. I'm sure I'll be begging for help on that one.... |
Lo-Fi Version | Time is now: 7th December 2025 - 02:08 PM |
