Door hinge plate loose..., the part that's riveted to the door.... |
falcor75 |
Mar 15 2014, 06:08 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
The part of the hinge that is riveted to the door is loose on my drivers side upper hinge, what's the forum's idea's if fixing this? Weld it in place on the door? Cut open the outer skin of the door and try to fix it that way?
Jeff Hail |
Mar 15 2014, 01:34 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
The part of the hinge that is riveted to the door is loose on my drivers side upper hinge, what's the forum's idea's if fixing this? Weld it in place on the door? Cut open the outer skin of the door and try to fix it that way? Dolly on one side and air hammer on the other to squeeze it tight. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:52 AM |
