FS 1976 2.0 fully optioned car. Mechanically almost new.SOLD, Excellent original condition. Nepal Orange SOLD |
Jakeodoule |
Mar 15 2014, 04:59 PM
Member Group: Members Posts: 353 Joined: 10-October 08 From: Des Moines Iowa Member No.: 9,630 Region Association: Pacific Northwest |
1976 Porsche 914 2.0
Fully optioned car with appearance group, rear defrost, sway bars original L20C Nepal Orange. 130,000 miles on car. Owners manual, tool kit and sales brochure still in car. 3 owners with pretty much all receipts since new. I have owned for car for almost 20 years. I really just sat on it for a while and then started the rebuild. Car has 8000 miles since engine rebuild. Originally a California car. Engine: 2.0 liter with stock fuel injection. Wiring harness unmolested. Engine completely rebuilt from crank out. No expense spared and all receipts are present. Runs perfect with no known issues. Starts and idles perfect hot, warm or cold. Pulls hard through all gears with no smoke on decel or acel. No backfires on decel. As you'll see by the list, my plan was to make the car mechanically perfect and presentable cosmetically. I wanted to drive it and not worry about a perfect paint job. All of this was done in the last 4 years with no more than 8000 miles on any of the new parts. Engine: Brand New parts include: Flywheel Sachs Power clutch and throw out bearing main bearings Scat enterprises street grind cam, bearings and aluminum cam gear Scat solid lifters push rod tubes heavy duty oil pump Mhele euro pistons,rings and cylinders. FI trigger points ignition points Scat valve springs and aluminuim keepers Brad Penn oil since rebuild. New engine mounts Reworked parts in engine: Crankshaft, polished, balanced and magnafluxed Heads, completely reworked with new seats, guides and head to cylinder surface machined Cases, Fully checked out and new crank bearings fitted and crank ground to match. Bursch muffler SS exchangers No exhaust leaks. New heater hoses Heat will cook you out of car! Fuel System: Tank removed and cleaned. Tangerine SS fuel lines in tunnel all new rubber lines injectors cleaned and balanced. new throttle position circuit board new fuel pump new throttle cable with spare in trunk Transmission: Fully rebuilt with assistance from Dr. Evil new seals all round new clutch cable with spare in trunk. New mounts Shifts perfect. All new shift bushings from trans to shift knob. This car shifts without flaw! Interior: ALL gauges work including clock. Keeps perfect time. All gauges in excellent condition with no scratches or rust on rings. Momo wheel with Momo shift knob Seats 9 of 10 with one spot on drivers left shoulder. New carpet with embroidered matts. pedal cluster rebuilt. no rust under pedal cluster. LED Gauge lighting with remote to change colors (super trick) also changes to yellow at 4 grand and red at 5 grand IPOD hook up with 4 JBL speakers. 2 in stock location and tweeters in coat hook locations. Bluapunt amp in front trunk. Stock radio works altho speakers are not hooked up to it. rebuilt both window crank/tracks, windows roll with ease. rear window defrost works. rear window removed and reset with 3M window seal. All switches and lights work. Fuse box unaltered and in stock condition. dash very clean with slight crack on backside. not visible from inside car. Top has all new seals. Suspension: front and rear stock swaybars Rearend completely rebuilt. new rear sway bar bushings New rear elephant suspension bushings new rear wheel bearings new rear Bilstien shocks. CV joints repacked with new boots Front partially rebuilt new wheel bearings new sway bar bushings. stock bilstiens Have not done suspension bushings. Front feels tight and smooth. Brakes: New rebuilt rear calipers from Eric. front calipers rebuilt. new 19 mm master clynder SS brake lines. E brake works perfect with clearences set at time of install. Stops perfectly straight with excellent pedal feel. New ferrodo pads Body: Saratoga clear top included. Altho its missing latches. Body is pretty much all original with a respray some 20 years ago. its very presentable with a few nicks here and there and one real scratch in left rear. At some point the PO over buffed it and wore through the paint on fender lips and few other places. rockers and jack points solid with no rust. original windshield with factory VW stickers front trunk is very clean and has all original carpet in excellent condition. Never been hit front or rear. some slight rust around the rubber track behind headlights. this is the worst rust on the entire car. rear trunk is super clean with no rust whatsoever. original padding in excellent condition and tool kit is complete. Cable release for rear truck lid so you never have to worry about trunk not opening. Rear reflector is one of the correct versions for the 914 it is NOT a cut down 911 version. look at the edges, they are finished. (very rare) I was offered $850 for this piece at the west coast ramble bumpers are very clean. Fog lights work Stock Fuchs that were professionally polished with the insets painted. (not a nick on them) oem centercaps LE air dam with no cracks. metal rockers battery tray has been replaced. Hell hole very clean. Area was treated and painted with Eastwood's rust sealer. Body was not rusted there. just the battery tray. top has new rubber seals all around the top. new window seals where the side window meets the sail panel All aluminum trim is in excellent condition. Sail panels like new. New Porsche letters on engine lid. Rain tray and tubes intact. Taillights in excellent condition. Goodyear eagle Tires like new with less than 2000 miles on them Optima battery Life has changed for me and I am down sizing for an extended motorcycle trip around the globe. I hate to see it go, but I find myself just not driving it enough to justify storing and maintaining it. Car is located in Des Moines Iowa. Will happily assist with shipping and or airport service if you want to arrive and drive. I wouldn't hesitate to jump in right now and drive this car anywhere. I know of nothing that needs attention. Just enjoy it and maybe paint it if you like. $13,000 or best. Very extensive spares and factory manuals can be purchased seperatly at very reduced price with the car. 952-917-9482 80 pictures at: http://s57.photobucket.com/user/johnclemen...20Porsche%20914 |
Dr Evil |
Mar 17 2014, 08:27 AM
I wanted to weigh in on this car. I have personally driven this car to the last WCR in Tahoe a few years ago. We drove from the Portland, OR area, down the back roads to Tahoe. I asked if I could open her up in a high mountain meadow where there were no cars, cops, or people and John said, with out hesitation, "Ya man, go for it". The pic is my smiling face in the reflection from the speedo (IMG:style_emoticons/default/smile.gif) This car is very nice and you will not be sad if you buy it.
Attached thumbnail(s) |
JRust |
Mar 17 2014, 12:18 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I also Drove John's car at Tahoe! He let me take it for one drive as my LE was stuck on the trailer. It drove great & John has done a nice job with this car. Well worth his asking price. You will be pleased with it for sure
Jakeodoule |
Apr 3 2014, 09:20 PM
Sale pending (IMG:style_emoticons/default/sad.gif)
MikeInMunich |
Jun 10 2015, 12:37 PM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
iMO, this car could have sold for $20,000 in the year it was sold, 2014. Lord knows it cost A LOT more to get it into the shape it was in at the time of this listing than 13k.
I personally think the owner was under estimating the value / demand for this excellent example. M.i.M. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:50 PM |
