What is this tail from? |
neo914-6 |
Jan 11 2005, 09:17 AM
Jay,
Following 80's Turbo styling, that tail is suitable for a Chalon. I mounted an AA tail to compliment the slopenose on my V8 914. Too visually extreme for most people but when you convert to V8 you have more "license" (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Martin, I am also interested in your intercooler flow management. I am zeroing in on my new powerplant and it will almost certainly be turbo charged, twin if the stars align correctly. A couple of us are researching rear mounted radiators as well for watercooled engines. Since they are 6's they won't need large capacity rads... |
Jan 11 2005, 12:40 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
just having the headlights up takes 10 km/h off your top speed. taking the top off is even worse. you do the math ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
andys |
Jan 11 2005, 01:11 PM
So what are we trying to fix (aero wise) with the spoiler? It is my understanding that the stock 914 has some rear lift at high speeds.....probably not much of a problem for a 4 cyl. street car, but a perhaps a 6, a track car, and a V8 could spell disaster if not properly managed. I have seen track cars with big rear wings; must be a reason for them. Another thing I read and saw photo's of, were vents to exhaust air trapped under the rear and/or engine bay that were cut into the rear tailight panel or the top of the trunk lid. I would think this would be the best first approach. FWIW.
Opinions on how the Turbo tail looks, is purely personal. Yes, a V8 car probably has some "license" for wings 'n things. Andy |
Jan 11 2005, 02:05 PM
yes. i don't have a problem with the (a) wing itself. my comment was about the louvers trapping air *inside* the wing, creating additional drag. if it hadn't the louvers, the wing would do what it's designed for, create downforce at higher speeds. right now, it does that + creating a lot of drag, which is bad. for this to work right, he either needs to close up the louvers (sp?) or create a way for the trapped air to exit (make holes on the back of the wing. from my understanding, the opening in the wing right now does not serve any purpose other than looks, so having the louvers is not neccessary ... just my 2 cents, (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
Mueller |
Jan 11 2005, 02:25 PM
he'd like to make the wing work for cooling.....I'm courious if it would work and how well...I know one 911 V8 guy mounts his radiators in the 930 type wing...would a setup similar work in a 914 if the appropriate holes are cut in the trunk floor??? |
Jeroen |
Jan 11 2005, 03:24 PM
the 930 (and carrera) 911 wings were designed as an exit for hot air
the air velocity over the wing will suck it out of the engine compartment (on a 911 that is) 930/911 turbo's have the intercooler sitting right underneath them but I think a 911 has much more air flowing over the face over the spoiler than the same spoiler would have on a 914 The targa hoop of the 914 f's up the airflow pretty good. From windtunnel pics I've seen from the 914, about 2/3's of the rear hood is a low pressure area and only the very last part of the hood gets some pressure again |
Maltese Falcon |
Jan 11 2005, 08:44 PM
Advanced Member Group: Members Posts: 4,636 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Rider914, I'm limited at this time on jpegs --due to needing to finish up scanner to PC (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) . There were a few good pix of the car (trunk open/closed) featured in "Excellence" June '03 issue.
Felix, the air management of the I-cooler setup works so well that you can toast your right hand and freeze the left if you hold the side tanks after a hard drive ! A coolant radiator would need to stand up more--as to not trap air pockets. This will be a design challange, you don't want the car to look like a WEC rallye racer (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Der Falconater |
neo914-6 |
Jan 13 2005, 03:21 AM
Mike, I'd like to see those...
Martin, (IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) but it would be nice to reduce, simplify the cooling system and the boxster dual rads aren't too tall. How much R&D did you do to get the I/C's right? |
Jeroen |
Jan 13 2005, 05:14 PM
here's the pic
Maltese Falcon |
Jan 15 2005, 12:32 AM
Felix, when I did the intercooler in '95, I simply bought the largest Spearco cooler offered 'cause you can't go wrong on the pressure drop (when going too big ) on the cfm. Too small of an intercooler will start scrubbing off boost--which is problematic when trying to fit certain size coolers in tight spaces. Turbonetics bought Spearco 2 years ago and their catalog has real good cfm flow charts for turbos, intercoolers, etc.
I recommend the catalog to DIY's , as it makes calculations real easy (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ! |
Lo-Fi Version | Time is now: 30th April 2024 - 08:09 AM |
