Clutch cable needs replaced, How hard of a job is this? |
boxsterfan |
Mar 24 2014, 09:28 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
So my clutch cable on 74 2.0L is starting to fray at the pulley. The fraying is occurring where the cable exits the "top side" of the pulley as it goes towards the adjusting nut. Pretty much right at the pulley.
Is this the common area for these cables to break? Or is it out of adjustment in some way that caused this excessive wear? I can order a new cable from Pelican Parts for $16.50, but is there an alternative (better?) cable to order that is more durable? Any other items I would need to order with this (pulley parts, lock nuts, etc...)? And how hard of a job is this replacement? |
JawjaPorsche |
Mar 24 2014, 10:03 AM
Not a hard job. I have heard pros and cons on more expensive clutch cables. Haynes manual is great for this job.
They like to break at the pulley. Replace now before you get stranded. Plus you will lose valuable hardware at the end of the cable. (IMG:style_emoticons/default/sad.gif) I carry a spare in my trunk! http://www.shoptalkforums.com/viewtopic.php?t=34340 |
AfricanHijinx |
Mar 24 2014, 10:07 AM
Member Group: Members Posts: 132 Joined: 12-April 11 From: Snohomish WA Member No.: 12,928 Region Association: Pacific Northwest |
its pretty easy to do the I got one from FLAPS and its seems to be ok so far
Jeffs9146 |
Mar 24 2014, 11:44 AM
Just be sure not to wrap around the accelorator cable! Otherwise very easy!
stugray |
Mar 24 2014, 12:37 PM
Sort of on topic: Where can we get replacement clutch pulleys?
PP says NLA. I would prefer one made from Aluminum. Who makes them? |
JawjaPorsche |
Mar 24 2014, 01:50 PM
Sort of on topic: Where can we get replacement clutch pulleys? PP says NLA. I would prefer one made from Aluminum. Who makes them? Auto Atlanta http://www.autoatlanta.com/Porsche-Clutch-...442325502D.html 914 Rubber http://shop.914rubber.com/914-Clutch-pulle...m?categoryId=-1 |
KELTY360 |
Mar 24 2014, 01:52 PM
914 Neferati Group: Members Posts: 5,030 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
914Rubber.com
malcolm2 |
Mar 24 2014, 02:07 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
So my clutch cable on 74 2.0L is starting to fray at the pulley. The fraying is occurring where the cable exits the "top side" of the pulley as it goes towards the adjusting nut. Pretty much right at the pulley. Is this the common area for these cables to break? Or is it out of adjustment in some way that caused this excessive wear? I can order a new cable from Pelican Parts for $16.50, but is there an alternative (better?) cable to order that is more durable? Any other items I would need to order with this (pulley parts, lock nuts, etc...)? And how hard of a job is this replacement? Buy 2 and keep one in the car to install on the road one day. |
toolguy |
Mar 24 2014, 03:14 PM
You want a plastic {Nylon / Delron} pulley, not metal. . metal ones will cause the cable to fray sooner. . far easier to change a pulley than a cable. .
stugray |
Mar 24 2014, 05:16 PM
Thanks all!
I looked at 914 rubber first but didnt find it first time thru Order placed! |
1970 Neun vierzehn |
Mar 24 2014, 08:24 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Boxsterfan,
I replaced my clutch cable for the last time back in 1979. Up until that time I kept the nylon pulley and cable clean and dry. It frayed and then separated. Back then, I ordered two clutch cables from Stoddard in Cleveland, so I would have one as a spare. I still have the second one as a "spare", and the replacement from 1979 is still on the car, and in fine shape. The solution to eliminate the fraying/separation of the clutch cable around the pulley assembly is to keep that area very well lubricated . I routinely inspect the cable and pulley and keep it slathered in white grease. As soon as the grease gets dirty and marginal looking, I wipe off the old lubricant and smear clean grease onto the cable & pulley. I'd say 30+ years on that cable validates my maintenance regime. Paul Attached thumbnail(s) |
partwerks |
Mar 24 2014, 10:06 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I made a bracket with a series of holes that I could keep moving it outward until I got to where I could get all the slack out of the cable. I have the pulley laying horizontal. I used a pulley off of a garage door spring, with a roller bearing in it. Just had to trim off about an 1/8" off the diameter for it to fit down into the saddle. Used square tubing to space it to where it goes towards the fork at an acceptable angle, and mounted the bracket to the same spot as the original. It pushes much easier.
abes914 |
Mar 24 2014, 11:02 PM
Member Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California |
i just replaced mine a month ago. fairly easy and i am not an expert wrencher. i ordered the terry cable from pelican parts. it seems more heavy duty compared to reg clutch cable.
boxsterfan |
Mar 25 2014, 09:31 AM
Thanks for all the tips here on this thread. I ordered a couple "regular" clutch cables from PP to arrive this week. My car already has a delron pulley from the PO. I'll take the advice of keeping it greased up as well.
boxsterfan |
Apr 5 2014, 07:39 PM
Changed out my clutch cable today. Not a bad/hard project, but having to take out the center console a bit annoying.
Glad I changed it though as this is what I was shifting gears with: Attached image(s) |
boxsterfan |
Apr 8 2014, 10:07 AM
Quick question about clutch cable adjustment:
Now that I have my new clutch cable in, shifting is definitely better. At what point should the clutch be engaging when pushing in the peddle? Closer to the top? Mine engages/disengages pretty close to the top. I have also heard that the cable may stretch some after a bit of use. |
JawjaPorsche |
Apr 8 2014, 10:54 AM
Quick question about clutch cable adjustment: Now that I have my new clutch cable in, shifting is definitely better. At what point should the clutch be engaging when pushing in the peddle? Closer to the top? Mine engages/disengages pretty close to the top. I have also heard that the cable may stretch some after a bit of use. It will stretch so adjustment maybe needed in a week or so. |
Jeffs9146 |
Apr 8 2014, 10:57 AM
I had to adjust mine 3 times over a month of driving before it settled down!
jaxdream |
Apr 8 2014, 11:21 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
What are some of the advantages of a horizontal pulley setup ??? Does the cable really know what the orintation is ??? Not trying to be a wise acre...as I have seen a few run the horizontal , Racer Chris maybe .
Jack |
ClayPerrine |
Apr 8 2014, 11:30 AM
Life's been good to me so far..... Group: Admin Posts: 15,410 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Funny... my 914 doesn't have a pulley. The clutch cable comes right out of the firewall and connects to the throwout arm.
(IMG:style_emoticons/default/biggrin.gif) I used a 71 911 trans case and the 225mm pull type clutch. That gives a stronger clutch, no clutch cable pulley, and no pressure on the clutch cable tube in the body. Next stop for me is a hydraulic clutch. |
Lo-Fi Version | Time is now: 25th April 2024 - 03:03 AM |
