Clutch cable needs replaced, How hard of a job is this? |
Apr 8 2014, 11:56 AM
boxsterfan |
Apr 17 2014, 09:11 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
So last weekend, I adjusted my new clutch cable after 1 week of driving. I ended up tightening the nut in a couple full turns. Now this week, it feels like it needs adjusted some more already.
I assume I should just be adjusting the nut a couple more full turns in each time until it stops stretching? Also, I believe I should be feeling clutch engagement/disengagement fairly highly on the clutch pedal? The shifting is good, but getting into first gear at stop stop is hit/miss. Sometimes super smooth and sometimes alot of jiggling to get it into gear. Also, second gear seems a little rough to get into at times. I'm guess I should have a look at my firewall bushing this weekend also. |
Apr 17 2014, 04:23 PM
Pull off the carpet over the center tunnel. Look through the hole in the gear shift lever base as you push the clutch pedal. If you see the cable moving left-to-right, the clutch tube has broken loose and you need to fix it.
--DD |
orthobiz |
Apr 17 2014, 04:51 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Clutch engages fairly high, not on the floor.
Paul |
boxsterfan |
Apr 18 2014, 09:54 AM
Pull off the carpet over the center tunnel. Look through the hole in the gear shift lever base as you push the clutch pedal. If you see the cable moving left-to-right, the clutch tube has broken loose and you need to fix it. --DD Thanks, I'll have a look this weekend since my center console is still out of the car. |
boxsterfan |
Apr 18 2014, 09:56 AM
Lo-Fi Version | Time is now: 25th April 2024 - 02:01 PM |
