American Racer Tires, Just ordered a set |
Randal |
Apr 7 2014, 09:00 AM
I ran them yesterday in the rain. There was very little standing water so I went with the slicks instead of my 888s. First impressions were pretty good although my driving sucked. Turn in is less crisp than with the A6s but it was an easy adjustment. They feel different under braking and I was having a hard time finding the threshold, granted the tire is a bit taller and it was wet out. I didn't find the limit through the slaloms but they would understeer just a bit mid corner before the back end would start to slide. Tire temps never got above 72 degrees with the rain. I started at 20 psi front cold and 19 psi rear cold and gained maybe 1 psi all around. I have another event this coming weekend so hopefully I can provide a better review. https://www.youtube.com/watch?v=LX2Urw2U5iQ 72 degrees? That is freezing for a slick; reminds me of the Medford Spring Enduro last year. You'll have some real fun when you find the temperature where the mechanical grip turns to sticky. |
Matt Romanowski |
Apr 7 2014, 12:13 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
How did you fit 275s on 8s? Those usually need at least a 9 and can go on a 10" wheel.
Woody |
Apr 7 2014, 01:06 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Matt Romanowski |
Apr 7 2014, 01:43 PM
I'm surprised you could fit a 275 on an 8" rim. That is not an optimal rim width for that tire.
Woody |
Apr 7 2014, 01:48 PM
I wasn't. I was running a 225 on the 8s.
Woody |
Apr 7 2014, 01:53 PM
I wouldn't try mounting a 275 A6 on an 8" wheel. With the 10" bias tire it doesn't seem to mind one bit.
Matt Romanowski |
Apr 8 2014, 07:54 AM
You should talk to the tire engineer and see what he says. You can shoe horn wide tires on narrow rims, but it rounds out the contact patch and you will actually lose grip. Bias plys will mount on narrower rims because of the flexibility in the carcass, but it's not always good.
koozy |
Apr 8 2014, 08:17 AM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
I'm looking forward to hearing what the results will be with warm/dry weather testing.
brant |
Apr 8 2014, 08:23 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
72 degree's ambiant or tire temp?
we have had a lot of TTOD in temps like that... the tires can still work if you have the right tire temp built up. |
Han Solo |
Apr 8 2014, 08:25 AM
Member Group: Members Posts: 288 Joined: 30-September 13 From: Middle Tennessee Member No.: 16,456 Region Association: South East States |
koozy |
Apr 8 2014, 08:29 AM
Woody |
Apr 8 2014, 04:42 PM
You should talk to the tire engineer and see what he says. You can shoe horn wide tires on narrow rims, but it rounds out the contact patch and you will actually lose grip. Bias plys will mount on narrower rims because of the flexibility in the carcass, but it's not always good. I would think this would be visible taking tire temps, no? The car is set up for staggered tires. My intent was to lose a little bit of tire width up front by squeezing the tires on the rims so I could kinda sorta maintain that stagger as I like the way the car feels. Yes, its probably not the right answer but I cannot swing for a set of Avons right now. 72 degree's ambiant or tire temp? we have had a lot of TTOD in temps like that... the tires can still work if you have the right tire temp built up. Tire temps immediatly after a run. Ambient may have been a little colder. A little off topic but... Woody, what type of fastener are you using on your fiberglass fender flares? I'm doing an autocross build and that would simply things greatly. Thanks! I am just using big headed 3/16 aluminum rivets with a fender washer on the backside. 72 degree's ambiant or tire temp? we have had a lot of TTOD in temps like that... the tires can still work if you have the right tire temp built up. 72 and wet? Daunting I have a few FTDs in the wet. These tires in my opinion felt better than the A6s in similar conditions. |
koozy |
Apr 8 2014, 04:45 PM
My car wilts in the rain
Woody |
Apr 14 2014, 07:25 AM
Well we had great weather yesterday and I got 5 good runs in. On a 35 second course the car is at least a half second faster than it ever was on the A6s, maybe a full second. The need for a TB diff is exagerated with this setup so I ended up going full stiff on the front bar. It helped but just masked the problem. Turn in was great, Haven't found the limit while in the slaloms and it seems very predictable mid corner. It was about 85 degrees ambient and I saw 110 on the tires which was close to what the other guys were seeing.
My two best runs. https://www.youtube.com/watch?v=exodqAGWBXQ https://www.youtube.com/watch?v=J1o1TbTK-dU |
koozy |
Apr 14 2014, 08:40 AM
Very interesting. What pressures were you running?
stownsen914 |
Apr 14 2014, 09:36 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
My car wilts in the rain Ha. Mine melts (IMG:style_emoticons/default/smile.gif) Open top car on slicks and rain - bad mix ... |
Woody |
Apr 14 2014, 11:16 AM
koozy |
Apr 14 2014, 11:31 AM
Ah, low pressures. They must have a robust sidewall. Very nice results. Can't wait to see how they hold up. What alignment specs are you running?
Woody |
Apr 14 2014, 12:18 PM
Woody |
Apr 14 2014, 12:19 PM
Lo-Fi Version | Time is now: 17th May 2024 - 07:14 PM |
