Undercoating - Ever Use Roofing Tar??, Undercoating |
ptravnic |
May 28 2003, 08:42 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
My pops is sold on $6 per gallon roofing tar for undercoating. Its worked on his cars for years - held up on my teener pretty well. Well, some structural work was just done in the typical areas & I'm proably gonna put some of the stuff on there.
I've heard the POR-15 ravings - is it really that much better. That stuff is expensive. Pete |
Gint |
May 28 2003, 09:15 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Huh? They're two entirely different things. I suppose if even my roof was rusty I would probably use POR-15 on it first before applying the roofing tar.
seanery |
May 28 2003, 09:22 PM
"Roofing Tar"
Run, Run, Run....That stuff will collect all the road debris you pass! Do the right thing! POR-15 |
Hawktel |
May 28 2003, 09:44 PM
Senior Member Group: Members Posts: 818 Joined: 2-April 03 From: Ogden Utah Member No.: 506 |
campbellcj |
May 28 2003, 10:37 PM
Undercoating is evil.... (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/devil.gif)
MarkV |
May 28 2003, 11:48 PM
How would you apply it? Would you use a trowel? (IMG:style_emoticons/default/confused24.gif)
GWN7 |
May 29 2003, 01:41 AM
Most undercoatings only work on new cars. The reason is the undercoating is applyed to a clean, newly painted surface. Even when new, the applicators wash and steam clean the underside of the car, to give the undercoater a clean surface to stick to.
POR15 and its counterparts create a chemical bond with the metal. All the tar will do is cover the metal. If there is a small hole in the tar it will hold water and cause rust. Most roofing tars don't "dry" compleatly. They are designed not to. They form a hard surface and are pliable underneath, so they can expand and contract with the shingles or as your house moves. Ever remove 20 yr old shingles? The tar they used around the flashings is usually still pliable. GravelGuard/under coater is a sprayable tar designed to protect the sides and underside of your car from rocks. It is thin, but the reason it works is that it "moves" when struck by the rocks. It still needs paint over it to protect it. If the surface the GG/undercoater is put on isn't compleatly clean, rust will form & it will fall off. Might take a year or two, but it will happen. Use a product for what it was intended. Why paint your whole house, when only the neibours look at the front? Because you will know that it's done right If your keeping the car, spend the extra $$, do it right. If your selling, spray/tar away. (IMG:style_emoticons/default/biggrin.gif) |
Gint |
May 29 2003, 07:46 AM
QUOTE If your keeping the car, spend the extra $$, do it right. If your selling, spray/tar away. Unless I'm buying, in which case I will run far away. |
May 29 2003, 11:14 AM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i hate undercoating.
it'll crack eventually and you can't see the rust behind it until it's too late. i'll remove all of it when i get to the underside of the car. actually, i will apply a new coat to the underside of the fiberglass fenders! that will protect the top paint from chipping when the underside is hit by pebbles ... other than that, just the paint, so i can see the rust when there's still time to do something about it ... Andy |
ptravnic |
May 29 2003, 11:22 AM
Surprisingly, general road debris does not stick to the tar. I do believe that if there is a small hole it may capture the very moisture (which is the devil) it is intending to prevent. An undercoating is not optional in this area. I don't have the luxury of a garage so something has to protect the undercarriage.
I'm beginning to believe POR-15 applied directly to the bare metal, then the tar over top would be a good mix. The tar has held up incredibly in the wheel wells! The tar can be applied not so easily with paint brushes - kinda like spreading peanut butter. For the POR-15, is the 3 step process necessary or is the POR-15 fine on its own applied directlly to somewhat clean bare metal??? |
May 29 2003, 11:41 AM
QUOTE(ptravnic @ May 29 2003, 10:22 AM) For the POR-15, is the 3 step process necessary or is the POR-15 fine on its own applied directlly to somewhat clean bare metal??? POR-15 can be applied to the bare metal. but i prefer to use "Metal-Ready" on the bare metal first, let that dry, then rinse it of with water (yes WATER!), let it dry again, then apply POR-15. that should do the trick. then put tar/undercoating over that. this way, if the undercoating cracks, the water still can't get to the metal ... Andy |
meursault |
May 29 2003, 01:05 PM
Idjit Savant Group: Members Posts: 290 Joined: 26-February 03 From: San Diego, CA Member No.: 355 |
Uggh. Roofing tar makes me cringe. Makes me think of how a PO sealed up the cowl on a parts car to deal with the rust there. Ugly. I'd almost prefer to see big bubbling mountains of rust.
BenNC |
May 29 2003, 02:18 PM
Member Group: Members Posts: 140 Joined: 7-February 03 From: Cary, NC Member No.: 267 |
POR-15 forms a very non-porous surface. I know they sell a special primer to get paint to stick it. Will the roofing tar or other undercoating have problems sticking directly to the POR-15?
GWN7 |
May 29 2003, 07:06 PM
It will stick to anything. (IMG:style_emoticons/default/biggrin.gif)
Try using it sometime. Have plenty of solvent to wash your hands, hair or whatever else touches it. Wear throw away clothes, Trevak suit recomended. There is 3 types of roofing tar that I know of (in Gal cans) Fiber-has fiberglass strands init. Put it on with a stick. Gel- works like peanut butter, can be painted on with a brush. Liquid- paint on or spray it. A buddy of my dads used to save his old oil, put it in a yard sprayer and spray it on the underside of his cars to prevent rust. It works too, but don't let the EPA catch you doing it. (IMG:style_emoticons/default/wink.gif) |
Mark Henry |
May 29 2003, 07:54 PM
QUOTE(GWN7 @ May 29 2003, 05:06 PM) A buddy of my dads used to save his old oil, put it in a yard sprayer and spray it on the underside of his cars to prevent rust. It works too, but don't let the EPA catch you doing it. (IMG:style_emoticons/default/wink.gif) DRIP, DRIP, DRIP Everyone oil their cars, so all the parking spots look like a Porsche or old V-dub lives there! (IMG:style_emoticons/default/laugh.gif) |
tracks914 |
May 29 2003, 08:13 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Most body shops can get a yellowy/clear K-Y type undercoating for your car. Here in Canada I have used it for about 15 years and get it done at the local WalMart. It never hardens and will weep out from your car for two or three years. (never enough to drip but enough to know it is still there and has to be washed off when you wash your car) For the amount of salt we use here I am very impressed with the way it holds out. I will never drive my teener in the salt but I will still get it sprayed too when I am done restoring it. I goes everywhere, inside the trunks lips, doors, fenders, rocker panels etc. Well worth the $75 for them to do it and cleaner too. (IMG:style_emoticons/default/MDB2.gif)
ptravnic |
May 29 2003, 09:47 PM
I am beginning to see a distinct difference in attitudes when comparing the Californians vs the Northeasterners & Canadians.....
I must admit, I envy the California sun and lack of rust-consideration. Maybe, I'll strike it rich on Wall St, retire, and move to So Cal where snow and salt are non-issues. ahhh, its good to dream |
driver66 |
May 29 2003, 10:03 PM
Member Group: Members Posts: 71 Joined: 11-May 03 From: sullivan,illinois Member No.: 678 |
anyone ever consider rhino lining for truck beds I hear its indestructable.
May 30 2003, 10:39 AM
QUOTE(ptravnic @ May 29 2003, 08:47 PM) I must admit, I envy the California sun and lack of rust-consideration. Maybe, I'll strike it rich on Wall St, retire, and move to So Cal where snow and salt are non-issues. ahhh, its good to dream haha, you don't have to "strike it rich on Wall St" to move here. in fact, all the people i know that made enuff money around here are gone, they all moved somewhere else. go figure ... Andy |
GWN7 |
May 30 2003, 03:14 PM
Bed liners are usually a epoxy based thick paint. It won't do a thing to stop rust unless it's applyed to a rust free part.
If it has rust on it now you have to stop the rust first, not cover it over. The 4 "C's" of rust...cut it out, clean it off, convert it, cover it. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:04 AM |
