Wideband Gauge, Who's running what? |
somd914 |
Apr 1 2014, 05:58 AM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Time to invest in wideband gauge to help get my carbs set up properly.
Any recommendations between AEM, Innovate, or others? Also, I prefer the look of analog as it would blend better with the VDO gauges in the console, but anyone have specific pros/cons between analog and digital beyond digital being easier to read a glance? |
Mark Henry |
Apr 1 2014, 06:24 AM
Time to invest in wideband gauge to help get my carbs set up properly. Any recommendations between AEM, Innovate, or others? Also, I prefer the look of analog as it would blend better with the VDO gauges in the console, but anyone have specific pros/cons between analog and digital beyond digital being easier to read a glance? You answered your own question on that...easier to read the better. I will say the analog only gauges suck just because they are hard to read. I personally only hook up my meter temporary (I tune a lot of cars with it), so I don't care if it matches my other gauges. I have a WMS and it's numbers are huge 1" to an 1-1/4" real easy to read even with peripheral vision. |
monkeyboy |
Apr 1 2014, 08:09 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I have an AEM in my car. I can't say I particularly care for the look of the big LCD numbers on my dash, but it is very easy to read.
iamchappy |
Apr 1 2014, 08:17 AM
I have an Innovate LC1 but it is very touchy clean power supply and grounds are the cure, but mine acts up now and then for no reason. I've considered replacing it..
kevin311 |
Apr 1 2014, 08:26 AM
Member Group: Members Posts: 105 Joined: 22-May 10 From: Tampa Bay Area Member No.: 11,752 Region Association: None |
I'm using an Innovate LC1 and despite some negative feedback online has beem rock solid for me. I am using it with the standard blue LCD gauge.
Krieger |
Apr 1 2014, 08:41 AM
Advanced Member Group: Members Posts: 4,721 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I like my AEM. I made a temporary bracket to hold it under my dash until things are sorted out.
somd914 |
Apr 1 2014, 09:27 AM
Thanks guys. I was considering mounting it in glove box since I keep nothing in there and could be seen when needed, or as Krieger said, a temporary under-dash mount.
But should I go for a console mount, are the LED models dimmable or always at full brightness looking like the Vegas strip at night? |
monkeyboy |
Apr 1 2014, 09:28 AM
My AEM is not dimmable, but it is not too bright.
iamchappy |
Apr 1 2014, 10:29 AM
Mounted mine on the post, not fancy but easy to see. Very critical with the turbo, the gauge i look at the most...
tradisrad |
Apr 1 2014, 10:43 AM
Innovate. The O2 sensor failed on me after 2 years. I was able to get a replacement from Autozone.
yeahmag |
Apr 1 2014, 03:41 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Old as hell Innovate LM-1. I mostly use it to spot check and then data log during track days.
stugray |
Apr 1 2014, 03:53 PM
Here's a ~5 minute datalog from a LC-1(Blue) and EGTs (Ylw & Or):
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1396389186.1.png) I dont have many hours on the LC-1yet so I cant comment on how reliable they are. |
Justinp71 |
Apr 1 2014, 06:07 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I've owned the LM-1 and the AEM, I like the AEM better, simpler to install and it doesn't need to be calibrated. The sweeping a/f bonus outer ring is nice, because you can see it out of the corner of your eye if you not able to stare at the gauge. Pillar mounting is probably ideal, I have mine at the ash tray and you have to look off the road to much while under WOT... (IMG:style_emoticons/default/smile.gif) |
crash914 |
Apr 1 2014, 06:42 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Tech Edge wide band o2.
WWW.wbo2.com |
wndsnd |
Apr 1 2014, 06:46 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
AEM is working for me. It also came with a couple of bezels and color changes.
John |
screenguy914 |
May 18 2015, 01:17 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
On Pelican Parts, user "Bisimoto" sells the latest AEM WB kit for a good price (~$155).
Sherwood |
Andyrew |
May 18 2015, 01:23 PM
I have also used an Innovate unit, I believe the LM1 unit.
I think there are much better kits on the market at this point as that unit is bulky and expensive. |
Andyrew |
May 18 2015, 01:24 PM
Whatever you get, get digital with record so you can watch your runs later. If you do things yourself its hard to watch the display when your driving and tuning.
May 18 2015, 01:32 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
no gauge, just a temporary setup to tune it, then once I am done, it goes back on the shelf.
Its pretty easy to know when the idle jets are clogged, and we dont really have any change in elevation around here. I will be putting in some data logging in my future EFI system, just to get it optimized....after that, its just too much information.... Rich |
toon1 |
May 18 2015, 03:17 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I was running an LC1 but it went belly up.
Just bought an LC2 kit but haven't installed it yet |
Lo-Fi Version | Time is now: 28th May 2024 - 12:19 PM |
