| Ferg |
Apr 1 2014, 04:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None
This could be a really silly question, but...
Went out for a drive a while back with Brant and used his wideband air/fuel tester to get a base line on how my 76 2.0 air/fuel mixture looks. Edit: Totally Stock Djet 2.0 We were getting readings close to at about 13.3 to about 14-14.5 at cruising/load. I know that is a little lean, but my smog pump is working, so wouldn't that trick the readings, and my actual is richer than whats read at the tailpipe? Does my logic make any sense? Ferg |
Ferg How will a working smog pump alter wideband Air/Fuel readings? Apr 1 2014, 04:08 PM
bulitt Yes, possibly. Ferrari's of the 80's had a... Apr 1 2014, 04:22 PM
Ferg Non CA 76 so no CAT.
I assume the pump is injecti... Apr 1 2014, 04:25 PM
Krieger Why don't you do two tests the same day. Do a... Apr 1 2014, 06:32 PM
Ferg Was thinking next time I'm at Brants may just ... Apr 1 2014, 08:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 11:11 AM |
