Which Fuel Filter? |
lennyhope |
Apr 5 2014, 04:05 AM
Member Group: Members Posts: 168 Joined: 2-November 11 From: prescot Member No.: 13,736 Region Association: England |
Which fuel filter type are you using? Since fitting one to my FI 1700 1973 car the engine is lumpy....Can they restrict the fuel flow and affect the injection?? It was running great before I fitted it along with a new Temp Head Sensor last week.
bdstone914 |
Apr 5 2014, 06:04 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Which fuel filter type are you using? Since fitting one to my FI 1700 1973 car the engine is lumpy....Can they restrict the fuel flow and affect the injection?? It was running great before I fitted it along with a new Temp Head Sensor last week. Could it be installed backwards? If so, the filter element may be smashed down restricting flow. Most filters flow into the center. |
lennyhope |
Apr 5 2014, 06:39 PM
Which fuel filter type are you using? Since fitting one to my FI 1700 1973 car the engine is lumpy....Can they restrict the fuel flow and affect the injection?? It was running great before I fitted it along with a new Temp Head Sensor last week. Could it be installed backwards? If so, the filter element may be smashed down restricting flow. Most filters flow into the center. I checked the flow is the right way... |
bdstone914 |
Apr 5 2014, 09:20 PM
Which fuel filter type are you using? Since fitting one to my FI 1700 1973 car the engine is lumpy....Can they restrict the fuel flow and affect the injection?? It was running great before I fitted it along with a new Temp Head Sensor last week. Could it be installed backwards? If so, the filter element may be smashed down restricting flow. Most filters flow into the center. I checked the flow is the right way... I would check fuel pressure. May not be the filter is the problem. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:43 PM |
