FS: Garage sale of massed gadgets., Sail panels, early 911 front end, 911 way bar, Head light switchs... |
ruby914 |
Apr 5 2014, 11:25 AM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
All prices do not include shipping.
I have an early 911 front end. Hubs, breaks, drop links, X-member, torsion bars, struts... (no sway bar) $250 for all. Sandblasting found rust through on the control arms. Consider them NG. Local pickup best. 911 sway bar $100 Head light switch $40 Hazard switch $25 Ashtray Triangle passenger glass $30 Engine lid torsion springs set Attached thumbnail(s) Attached image(s) |
photos |
Apr 5 2014, 02:30 PM
Newbie Group: Members Posts: 3 Joined: 10-November 11 From: Fort Wayne, IN Member No.: 13,765 Region Association: Upper MidWest |
PM sent for the Sail Panels...
GainStatus |
Apr 5 2014, 03:59 PM
I'm new here ... Group: Members Posts: 0 Joined: 28-January 14 From: Iowa Member No.: 16,938 Region Association: None |
PM sent on front suspension stuff.
ruby914 |
Apr 5 2014, 09:51 PM
GainStatus, your 2nd in line by 45 minutes.
Not crazy about shipping this, the box is about 100# but I am looking into it. With the interest in this front end, let me give some more info. I want to be clear, this is an Early 911 front end (65-68). It is not best for a 914 conversion. If you look at how the strut attaches to the control arm, It is quite different than the late or 914s. I learned this the hard way. Includes: Breaks; non-vented disks, T calipers with 3" bolt spacing. In this photo you can see a dent in one of the hubs. |
JeffBowlsby |
Apr 6 2014, 09:54 AM
914 Wiring Harnesses Group: Members Posts: 8,439 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Please tell us why the switches were cut off this harness and not just disconnected?
That harness is now destroyed. Good condition harnesses are becoming hard to find and there is never a valid reason to cut any wiring, everything simply disconnects. Attached image(s) |
ruby914 |
Apr 7 2014, 12:18 AM
Please tell us why the switches were cut off this harness and not just disconnected? That harness is now destroyed. Good condition harnesses are becoming hard to find and there is never a valid reason to cut any wiring, everything simply disconnects. Jeff, I do not recall. (IMG:style_emoticons/default/unsure.gif) I do recall a car at a pick and pull about 5 years ago. It was picked clean, in the crusher line. I remember fiddling for a switch in a rush to get to work. I could have cut it, but I have the set and don't remember a full set or if I left it? I also remember a box of extras that came in the white WRX car I am working on now. Good chance it was in that box? Speaking of the white WRX car I sold the motor with the FI, ECU, relay board and Motor harness. I used most of the Subaru harness so removed the 914 harness. Well, (IMG:style_emoticons/default/sad.gif) removed most of it. Yes, I cut it at the points that I spliced into. Wires like the turn signals, horn, door switches stayed in the car. Here are the light switches from the WRX car. I didn't know if the remains of the harness were worth anything? PM me if you want it. Wires are free, I will cover the shipping. I will go out and take another photo of everything in that box. If you want the switches and everything else that went with it, make me an offer. Jeff, I hope the 2nd photo isn't too hideous. Attached image(s) |
ruby914 |
Apr 20 2014, 02:09 AM
914 front calipers $70 + shipping for the top set.
$35 each for the bottom two. Bottom R is an early passenger side (single bleeder) front and the other three are late front that can mount on either side. All 4 for $110. Attached image(s) |
sixnotfour |
Apr 20 2014, 06:40 PM
914 Wizard Group: Members Posts: 10,392 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
914 fog light switch $25 yes please
ruby914 |
Apr 20 2014, 11:35 PM
John8475 |
Apr 21 2014, 10:39 AM
Newbie Group: Members Posts: 2 Joined: 15-October 13 Member No.: 16,519 Region Association: Pacific Northwest |
PM sent on Fuel Sending unit
ruby914 |
Apr 22 2014, 05:16 PM
ruby914 |
May 15 2014, 01:38 PM
If they are broken up $30 each arm $20 for the torsion bar set. Sold to the trash man. Attached image(s) |
ruby914 |
Jul 13 2014, 11:48 PM
ruby914 |
Nov 18 2014, 11:59 AM
Pre Christmas bump!
Su Subaru 2.0/2.2 KEP adaptor kit to 228mm Porsche 914, 901 transaxle. New was $540 Used $250 Stage 2 Porsche heavyduty pressure plate, stock disk, Porsche T.O.B and bolts. New was $354 Used $150 Cable shift: (2) cables, rear side-shift linkage, cable ends may or may not be included. Shifter and Fwd linkage not included. $125 Hi torque starter $150 VSS $9.14 Attached image(s) |
ruby914 |
Dec 28 2014, 12:56 PM
After X-Mas bump
-JR- |
Dec 29 2014, 12:26 AM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
Front control arms set with torsion bars $60 If they are broken up $30 each arm $20 for the torsion bar set. What are these control arms off of? They look similar to a taco'ed 911 control arm I'm trying to replace for my teen project. Any part number on the left hand one? Could you post a picture of the ball joint pin area so I can tell what type it is? Thanks! |
colingreene |
Dec 29 2014, 01:31 AM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
What size is the sway bar, I am interested.
ruby914 |
Jan 1 2015, 11:16 AM
ruby914 |
Jan 1 2015, 11:40 AM
Front control arms set with torsion bars $60 If they are broken up $30 each arm $20 for the torsion bar set. What are these control arms off of? They look similar to a taco'ed 911 control arm I'm trying to replace for my teen project. Any part number on the left hand one? Could you post a picture of the ball joint pin area so I can tell what type it is? Thanks! The control arms came from a 73 914. I had to tip-e-toe thru the freshly planted grass seed to see if I still had these. I do have the LH side. I may have thrown the RH side out? I will take a closer look a little later when the day warms up and I wake up. |
ruby914 |
Jan 1 2015, 04:27 PM
They were sitting out in the rain. Surprisingly the ball joint moves smoothly and feels good. They should clean up well. For the LH arm, torsion bar Attached thumbnail(s) |
Lo-Fi Version | Time is now: 29th March 2024 - 04:55 AM |
