malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
Just helped remove a 1.7 today and this is what came out of it.
There were probably 4 push rods that had varying amounts of this wear. I could make a guess at what caused it, but this end was seated in the lifter. Just curious.... anyone want to guess? ![]() |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
wow that was close to failure!
the pushrod retainer spring was installed wrong and it has been rubbing. Apparently for a long time. |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Push rod tube retainer spring is installed improperly and rubbed against the push rod....for a while it looks like.
malcolm2 |
Push rod tube retainer spring is installed improperly and rubbed against the push rod....for a while it looks like. That is what I thought. But the end with the notch was opposite the end with the spring. All the rods with damage were seated in the lifters. I pulled the 1st one out and said, "man, I wonder what that lifter did to the push rod." So the next guess is that someone did a tremendous dis-service and installed junk parts. |
stugray |
maybe that's someone's idea of lightening the valve train (IMG:style_emoticons/default/confused24.gif)
Bob L. |
Senior Member ![]() ![]() ![]() Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region ![]() |
Maybe the DAPO flipped them around when they noticed it? (IMG:style_emoticons/default/confused24.gif)
Black22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest ![]() |
That actually looks machined! Almost too perfect for rubbing on the retaining wire.
(IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/confused24.gif) |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,752 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
That actually looks machined! Almost too perfect for rubbing on the retaining wire. (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/agree.gif) That looks like it was turned on a lathe. And it's not on the spring end. Zach |
VaccaRabite |
That was turned on a lathe. Someone goofed on their geometry and started shortening the pushrod. The left cut is the same angle as the shoulder and the groove is the same length as the pushrod tip.
LOL! |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
If the lifter is doing its job right, it spins a little each time it moves. So the pushrods turn with it and this is what you get.
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Nope, retaining wire got it.. It was probably inverted at some point by someone who didn't care, or didn't know any better.
The pushrod rotates as it reciprocates, which is what leads to this perfectly machined surface. |
MrHyde |
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None ![]() |
That looks like one "spirited drive" away from becoming 2 pieces
stugray |
That just makes me wonder how much we could machine off the pushrods and they would be fine.
Every gram we take off the valve train helps (IMG:style_emoticons/default/biggrin.gif) |
Jake Raby |
That just makes me wonder how much we could machine off the pushrods and they would be fine. Every gram we take off the valve train helps (IMG:style_emoticons/default/biggrin.gif) Just because it lives doesn't mean that it won't deflect.. Deflection costs lift and duration at the valve. |
veekry9 |
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada ![]() |
Turned on a lathe with a TNMG insert.
![]() so.. you want to machine. Titanium Nitride coated by vapour deposition. tnmg is the code descriptor of one of thousands of configurations available. the catalogs are great tomes too large to print these days so we download pdfs. //http://www.sandvik.coromant.com// |
McMark |
Turned on a lathe with a TNMG insert. Teenage Ninja Mutant Gecko? Attached image(s) ![]() |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Push rod tube retainer springs? (IMG:style_emoticons/default/confused24.gif) I'm not sure what you're talking about. (IMG:style_emoticons/default/av-943.gif)
Black22 |
Jake Raby |
Dual springs with stock rocker studs.. Playing with fire!
Elliot Cannon |
Playing with fire for 25,000 miles. So far, so good. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 1st July 2025 - 02:05 AM |
